hi have had this recorder for 2 years now and it has suddenly stopped reading dvds,...
i decided to have a look under the hood to see if if there was anyderis on the lens but nothin....the reason im writing this post ...the dvd drive in the goodmans recorder is a ricoh dvd writer ....which looks the same as any dvd rewriter in a pc ...
silly question to anyone out there.....could i replace the drive with another standard pc dvd rewriter which is used is a pc??
can anyone help me this ...thank you![]()
It works for some models. And you will likely have to replace it with the exact same brand and model.
Google is your Friend
Looking for sound card recorder (not Total Recorder)
By jimdagys in forum AudioReplies: 1Last Post: 7th Jan 2011, 20:23 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 03:05 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 05:54 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 22:19
