I'm a pretty new Mac user (moved from Windows about 3 months ago)
Is it possible to export an iMovie (ver. 7.1) project as a DivX file?
I installed the latest DivX codec from the DivX website but can't find any option in iMovie to export as a DivX file.
I have found many posts and even videos explaining how to do this but using previous versions of iMovie (i.e. ver 5) that don't match with the current one.
The purpose is to play the videos in my DVD player. I've tried several other export formats but the player doesn't recognize them.
My setup just in case is:
Macbook
OS X 10.4.11
iMovie'08 (ver 7.1)
I'd really appreciate any help.
				Results 1 to 9 of 9
	Hello and welcome to our world!
 the easiest thing to accomplish what you wish is
 to get Toast titanium 8 ( if running leopard make sure
 it is patched to version 8.03).
 You export your finished movies from iMovie,
 as Quicktime .mov files. Open
 Toast 8, and select under the video tab,
 "Burn DIVX Disc".
 then, you
 drag and drop the .mov files into the open window,
 and click burn DVD ( the green button) in the left corner.
 Once done, you have a divx compatible disc ready to play."Everyone has to learn, so that they can one day teach."
 When I'm not here, Where can I be found?
 Urban Mac User
	I'm not aware of any way to directly export from iMovie 7 to DivX. You first must export to a file that either Toast or the DivX Converter application can read, such as what terryj suggests.
	There is an easier way. And you don't have to export your movie from iMovie at all. Both Toast and Visual Hub recognise an iMovie project as if it were a self-contained video file. Just save and close your iMovie project and drag it directly into the Toast or Visual Hub window and you can export directly as DivX from either of these.
 The only problem I have found with this method is that, if your iMovie project is 16:9 aspect ratio, both Toast and Visual Hub read it as 4:3. So, it is necessary to manually specify the exact horizontal and vertical resolutions you want the DivX to be, for example 720:400 or 640:352 or whatever.
 Really simple. Good luck.
	That works with Toast and iMovie HD but not with the iMovie that's part of iLife 08. The new one doesn't have a project file that Toast can recognize. I don't know about Visual Hub.
	Thanks for that Frobozz. Hee hee, I am so glad I didn't upgrade iLife 08 when I had the opportunity. I really like having the ability to drag my projects straight into Toast and Visual Hub.
	Thanks everyone for your answers
 Surfmonkee, I don't see any divx option either. May be it was there in previous iMovie versions but not in 7.1. Anyway, it's good to know that I wasn't missing an option hidden somewhere.
 I'll take a look at the applications you guys have suggested.
 cheers.
  export from iStopMotion to edit in iMovie 09By kvdv in forum MacReplies: 19Last Post: 29th Sep 2009, 09:56
  VOB to MPEG to MOV to export to iMOVIE HD 06 HELP PLEASE!By HowardNeedsHelp in forum MacReplies: 5Last Post: 16th Aug 2009, 07:15
  which format should i export my imovie projects toBy Lu-min Chew in forum Video ConversionReplies: 1Last Post: 6th May 2009, 03:18
  Export Full Quality iMovie '08By jooleyen in forum MacReplies: 2Last Post: 3rd Oct 2008, 17:20
  iMovie '08 -- Can't find export to DV camcorder in new menusBy edDV in forum MacReplies: 1Last Post: 11th Feb 2008, 00:44
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
