I ripped a chapter from a DVD to elementary streams using DVD Decrypter, converted the AC3 to WAV using ac3Tool, then used Cuttermaran to crop the video and audio.
Now I want to take those cropped files and convert them back to a VOB file so I can convert that new VOB file to mp4 to use in my iPod (using VeMoDe).
What program can I use to remux the wav & m2v files to a VOB? Freeware would be much preferred.
Thanks for any help.
.....Gord
Outside a dog a book is man's best friend. Inside a dog it's too dark to read.
------------ Groucho Marx -
I'm not sure why you would want to convert to a VOB, just to convert to a MP4 format.
It appears VeMoDe can convert from MPEG. You might try ImagoMPEG-Muxer or you could use TMPGEnc -2.524.63.181-Free just for muxing. That function is in 'File>MPEG Tools'.
Yeah, it sounds like the long way around to me as well. However, the free Muxman will do what you want. Add in the M2V and the WAV audio, give it a destination and "Start". And depending on the max bitrate set for the M2V, there's a chance that your conversion of the AC3 audio to WAV audio will push the max acceptable DVD bitrate over the top and the authoring will fail. You'll never know until you try, though.
demux from vob to m2v
By brucexx in forum Video ConversionReplies: 6Last Post: 17th May 2010, 07:56 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 21:25 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
VOB to AVI back to VOB
By fatla00 in forum Authoring (DVD)Replies: 23Last Post: 11th Oct 2007, 04:28
