Hey guys I've been ripping a bunch of dvds of sitcoms I have to my computer and I'm trying to get the audio sync perfect. I can't tell just by watching whether it is out of sync or not. I keep thinking it is, but that might be just cause I'm looking too hard at their mouths. Also, whenever I open the episodes in virtualdub the streams are different lengths. I also noticed that Gordian Knot adds a few frames to the final product, because a final episode usually has 3 or more frames then the original. Anyway, I'm really confused, and I can't really notice the audio and video out of sync (or maybe I can). Should I just leave it alone and forget about it, or try to get the audio sync on the dot mathematically?
Tim
If it's so close that you aren't sure, I would just leave it alone.
Google is your Friend
Gordian Knot AUDIO PROBLEM: DTS to VBR MP3? (HD 720p.mkv to SD XviD.avi)
By Randm in forum Video ConversionReplies: 2Last Post: 31st Jul 2009, 01:49 -
Auto Gordian Knot, a/v out of sync
By takearushfan in forum Newbie / General discussionsReplies: 13Last Post: 22nd Feb 2009, 13:08 -
Major problem loading audio from AVI file into Auto Gordian Knot v 2.45
By robo5050 in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2008, 06:12 -
using Gordian Knot
By ricmetal in forum Video ConversionReplies: 3Last Post: 6th Dec 2007, 14:20 -
Gordian Knot help
By zookeeper525 in forum DVD RippingReplies: 25Last Post: 16th Aug 2007, 00:49
