I'm looking at buying a dvd recorder/VCR combo with XViD playback, but I can't afford to spend much. I was hoping for US $150 or less counting shipping costs. I looked at a few of the models at a local department store, but most of them have bad reviews. Can anyone recommend a good unit for this? Most of my movie collection is XViDs recorded from cable and put on DVD-R. My TV is an old fashioned standard res. TV. I'd also like to back up my VHS collection to DVD to free up some space in my entertainment center.
I found a good deal on a Panasonic DMR-ES35V. I know it plays DivX, but I don't know if this model will playback XViDs. Does anyone know?
Divx and Xvid are very similar. If you use a Xvid encoded with the same settings as a Divx that works on your player, you should have no problems. Some converters like AutoGK can use either codec and output Divx player compatible output.
I copied this from a post about encoding settings that aren't usually compatible with most set top Divx players:
Also, VBR audio might cause problems with some players, as well. If your AVIs have any of the above, you might need to modify/recompress them before they'll play on your player.Originally Posted by jman98
BTW, just personal preference, but I wouldn't get a unit that has both a VHS player/recorder and a DVD recorder in the same unit. For one reason, Macrovision on VHS tapes will cause problems when backing up a tape and the mechanical part of the VHS player may fail long before the DVD recorder part. -
Philips makes a dvd recorder with 80gig hd & plays divx but it's more than you want to spend. There are very few dvd recorders what play divx, so it's not like you have much choice. Plus, you could just get a dvd/divx player for a lot cheaper & then also have a dvd recorder. Dvd recorders these days come with hd tuners.
https://www.videohelp.com/dvdrecorders
Looking for sound card recorder (not Total Recorder)
By jimdagys in forum AudioReplies: 1Last Post: 7th Jan 2011, 20:23 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 03:05 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 05:54 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 22:19
