How would I go about editing a video to make it look like a CNN episode?
I basically want some type of text running on the bottom, while my video is playing.
And, if possible I want to have two different clips on the screen at once: each taking up half the screen.
What program would I use to add that type of feature?
How would I use that program to do such things?
Thanks in advance,
Locus
Sort of like the old story "How do I get to Carnegie Hall?"
Answer: Practice Practice Practice
It could be done with most any full prosumer edit package like Premiere Pro or Vegas Pro but it may take you months to learn how.
CNN does it with expensive graphics generation equipment and a large scale digital production switcher.
http://www.kiva.org/about -
Any good editor will do this - Vegas Pro, Premiere Pro, Media Studio Pro, FCP. Some of the mid-level editors can also probably do it - Vegas Movie Studio, Premiere Elements.Originally Posted by locuspoint
You would read the manual and learn how the program works. In Vegas, the terms to read up on include 'overlay', 'track motion' and 'event pan and crop'Originally Posted by locuspoint
Every program uses similar yet different terms, so it is difficult to give exact instructions without knowing what you are intending to use. Pick a tool, then come back and you will get some more specific.Read my blog here.
Study the CNN format
It's not much more than a moving background, main content, and some semi-transparent gradient color bars with text
Then add your moving marquee at the bottom...
Why does the video I edit in Cyberlink look darker after I edit it and post
By Chubby Johnson in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2010, 06:08 -
Is Yahoo using more local news in its main news window?
By yoda313 in forum Off topicReplies: 3Last Post: 12th May 2010, 23:09 -
JOB: Video & Screen Cast Creator
By worketc in forum Off topicReplies: 1Last Post: 21st Apr 2010, 01:45 -
need help in choosing a format after video edit (DV then edit then DVD)
By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 14:13
