Hi and thanks in advance. I have a project that I authored with tmpeg and had previously burned with all OK. I recently tried to burn using Nero (not with the burning tool with TMPEG like previously) and always get errors. I tried with 2 different DVD-RW's one is a bit older, but the other is new, neither gave me troulbe before. Here's the logs in case anyone can help as to what went wrong, thanks again!
LOG1:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Archivos de programa\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02/11/2004 12:54:32 p.m.
NT-SPTI used
Nero Version: 7.0.1.2
Internal Version: 7, 0, 1, 2
Recorder: <_NEC DVD+-RW ND-6500A> Version: 2.40 - HA 1 TA 0 - 7.0.1.2
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <_NEC DVD+-RW ND-6500A>Version: 2.40 - HA 1 TA 0 - 7.0.1.2
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG MP0603H atapi Port 0 ID 0 DMA: On
CdRomPeripheral : _NEC DVD+-RW ND-6500A atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
_NEC DVD+-RW ND-6500A D: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 511MB (523628kB)
Free physical memory: 164MB (168708kB)
Memory in use : 67 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
12.1.2008
UDF/ISO compilation
02:37:59 p.m. #1 Phase 112 File dlgbrnst.cpp, Line 1725
DVD-Video files reallocation started
02:37:59 p.m. #2 Phase 114 File dlgbrnst.cpp, Line 1725
DVD-Video files reallocation completed (no file modified)
02:37:59 p.m. #3 Text 0 File Isodoc.cpp, Line 6411
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Revision : 1.02
UDF Partition Type : physical
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet :FALSE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
02:37:59 p.m. #4 Phase 111 File dlgbrnst.cpp, Line 1725
DVD-Video files sorted
02:37:59 p.m. #5 Text 0 File ThreadedTransfer.cpp, Line 525
ReadBuffer-Pipe got 72704KB of Memory
02:37:59 p.m. #6 Text 0 File Reader.cpp, Line 124
Reader running
02:37:59 p.m. #7 Text 0 File Writer.cpp, Line 113
Writer D: _NEC DVD+-RW ND-6500A running
02:37:59 p.m. #8 ISO9660GEN -11 File Geniso.cpp, Line 3312
First writeable address = 0 (0x00000000)
02:37:59 p.m. #9 ISO9660GEN -11 File Geniso.cpp, Line 3312
02:37:59 p.m. #10 Text 0 File Burncd.cpp, Line 3302
Turn on Disc-At-Once, using DVD media
02:39:07 p.m. #11 Text 0 File DlgWaitCD.cpp, Line 279
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2248831 (499:44.31, 4392MB)
02:39:07 p.m. #12 Text 0 File DlgWaitCD.cpp, Line 291
Write in overburning mode: NO (enabled: CD)
02:39:07 p.m. #13 Text 0 File DlgWaitCD.cpp, Line 2578
Recorder: _NEC DVD+-RW ND-6500A, Media type: DVD-RW
Disc Manufacturer: TDK601 - saku
Disc Application Code: 2, Disc Physical Code: 214
02:39:07 p.m. #14 Text 0 File DlgWaitCD.cpp, Line 458
>>> Protocol of DlgWaitCD activities: <<<
This disc is not empty.
(Medium in drive: DVD-RW. Medium required by compilation: DVD+R/RW, DVD-R/RW, DVD+R DL.)
VMS. Disc was erased successfully.
Accessing disc...
02:39:07 p.m. #15 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2248832 (2248832) = #2248832/499:44.32
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2248832 blocks [D: _NEC DVD+-RW ND-6500A]
02:39:07 p.m. #16 Text 0 File Burncd.cpp, Line 3894
Can only write at 2x (2.770 KB/s) instead of 2,4x (3.324 KB/s) to current disc.
02:39:07 p.m. #17 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [D: _NEC DVD+-RW ND-6500A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4605607936, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2248832 | lead-out | 1 | 0x41 | 0x00
02:39:08 p.m. #18 Text 0 File SCSIPassThrough.cpp, Line 36
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
02:39:08 p.m. #19 Phase 24 File dlgbrnst.cpp, Line 1725
Caching of files started
02:39:08 p.m. #20 Text 0 File Burncd.cpp, Line 4132
Cache writing successful.
02:39:08 p.m. #21 Phase 25 File dlgbrnst.cpp, Line 1725
Caching of files completed
02:39:08 p.m. #22 Phase 36 File dlgbrnst.cpp, Line 1725
Burn process started at 2x (2.770 KB/s)
02:39:08 p.m. #23 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
02:39:08 p.m. #24 Text 0 File DVDR.cpp, Line 2580
Recording mode: Sequential Recording Mode
02:39:08 p.m. #25 Text 0 File MMC.cpp, Line 21611
Set BUFE: JustLink -> ON
02:39:08 p.m. #26 Text 0 File DVDR.cpp, Line 2735
Start write address at LBA 0
DVD high compatibility mode: Yes
02:39:08 p.m. #27 Text 0 File Cdrdrv.cpp, Line 8411
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-RW (3), Part Version: - (3)
Disc Size: 120 mm, Maximum Rate: 10.08 Mbps (2 h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 2EE10 h
Start sector number of the next Border-In: 2EEA0 h
Media Specific [16..63]:
00 20 10 00 00 00 00 00 - 00 00 03 12 00 00 00 00 ................
00 02 EE 10 00 02 EE A0 - 00 00 00 00 00 00 00 00 ..î...î.........
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
02:39:10 p.m. #28 Text 0 File Cdrdrv.cpp, Line 1197
14:39:10.640 - D: _NEC DVD+-RW ND-6500A : Queue again later
03:06:34 p.m. #29 SPTI -1135 File SCSIPassThrough.cpp, Line 323
D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 22 34 60 00 00 20 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x036a0000: Len x10000
0x00 00 01 BA 44 01 35 F6 E4 2B 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 3C E5 C6 10 62 3D A2 46 F8
0xA2 5B 4D A4 EA B4 D2 A2 87 74 17 C2 9A 29 E8 6C
03:06:34 p.m. #30 CDR -1135 File Writer.cpp, Line 302
Write error
03:06:34 p.m. #31 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
03:06:34 p.m. #32 Text 0 File DVDR.cpp, Line 2978
EndDAO: Last written address was 2241631
03:06:34 p.m. #33 Phase 181 File dlgbrnst.cpp, Line 1725
Writing lead-out...
03:06:34 p.m. #34 Text 0 File DVDR.cpp, Line 3011
Estimated time for 30mm Borders: 0min 00sec
03:06:34 p.m. #35 Phase 38 File dlgbrnst.cpp, Line 1725
Burn process failed at 2x (2.770 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.12a, size=20576 bytes, created 30/08/2007 07:45:43 a.m. (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
AND HERE'S LOG 2:
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Free physical memory: 163MB (166924kB)
Memory in use : 68 %
Use Inquiry : 1
12.1.2008
UDF/ISO compilation
03:11:42 p.m. #1 Phase 112 File dlgbrnst.cpp, Line 1725
03:11:42 p.m. #2 Phase 114 File dlgbrnst.cpp, Line 1725
03:11:42 p.m. #3 Text 0 File Isodoc.cpp, Line 6411
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
UDF Revision : 1.02
Joliet :FALSE
03:11:42 p.m. #4 Phase 111 File dlgbrnst.cpp, Line 1725
03:11:42 p.m. #5 Text 0 File ThreadedTransfer.cpp, Line 525
03:11:42 p.m. #6 Text 0 File Reader.cpp, Line 124
Reader running
03:11:42 p.m. #7 Text 0 File Writer.cpp, Line 113
03:11:43 p.m. #8 ISO9660GEN -11 File Geniso.cpp, Line 3312
03:11:43 p.m. #9 ISO9660GEN -11 File Geniso.cpp, Line 3312
03:11:43 p.m. #10 Text 0 File Burncd.cpp, Line 3302
03:12:24 p.m. #11 Text 0 File DlgWaitCD.cpp, Line 279
03:12:24 p.m. #12 Text 0 File DlgWaitCD.cpp, Line 291
03:12:24 p.m. #13 Text 0 File DlgWaitCD.cpp, Line 2578
Disc Manufacturer: MCC 01 - RW11n9
Disc Application Code: 64, Disc Physical Code: 214
03:12:24 p.m. #14 Text 0 File DlgWaitCD.cpp, Line 458
Disc not empty. Insert empty disc.
Accessing disc...
03:12:24 p.m. #15 Text 0 File ThreadedTransferInterface.cpp, Line 847
03:12:24 p.m. #16 Text 0 File ThreadedTransferInterface.cpp, Line 1059
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
03:12:24 p.m. #17 Text 0 File SCSIPassThrough.cpp, Line 36
03:12:24 p.m. #18 Phase 24 File dlgbrnst.cpp, Line 1725
03:12:24 p.m. #19 Text 0 File Burncd.cpp, Line 4132
03:12:24 p.m. #20 Phase 25 File dlgbrnst.cpp, Line 1725
03:12:24 p.m. #21 Phase 36 File dlgbrnst.cpp, Line 1725
03:12:24 p.m. #22 Text 0 File ThreadedTransferInterface.cpp, Line 2685
03:12:24 p.m. #23 Text 0 File DVDR.cpp, Line 2580
03:12:24 p.m. #24 Text 0 File MMC.cpp, Line 21611
03:12:24 p.m. #25 Text 0 File DVDR.cpp, Line 2735
03:12:24 p.m. #26 Text 0 File Cdrdrv.cpp, Line 8411
Book Type: DVD-RW (3), Part Version: 1.1x (2)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Data in Burst Cutting Area (BCA) exist
80 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
03:12:26 p.m. #27 Text 0 File Cdrdrv.cpp, Line 1197
15:12:26.765 - D: _NEC DVD+-RW ND-6500A : Queue again later
03:34:51 p.m. #28 SPTI -1135 File SCSIPassThrough.cpp, Line 323
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 1C 80 00 00 00 20 00 00 00
Buffer x070d0000: Len x10000
0x00 00 01 BA 44 0C 67 84 96 2D 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 76 62 73 64 99 2A D9 6D A4
0x96 A7 97 73 93 0D 99 B2 ED 35 2D 0D 87 10 9A D1
03:34:51 p.m. #29 CDR -1135 File Writer.cpp, Line 302
Write error
03:34:51 p.m. #30 Text 0 File ThreadedTransfer.cpp, Line 228
03:34:51 p.m. #31 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
03:34:51 p.m. #32 Text 0 File DVDR.cpp, Line 2978
EndDAO: Last written address was 1867775
03:34:51 p.m. #33 Phase 181 File dlgbrnst.cpp, Line 1725
Writing lead-out...
03:34:51 p.m. #34 Text 0 File DVDR.cpp, Line 3011
03:34:51 p.m. #35 Phase 38 File dlgbrnst.cpp, Line 1725
Existing drivers:
Registry Keys:
Thanks again!
winxp - 3.06 -
Suggest you get some decent blank disks like Verbatim or TY and
burn with the software recommended by aedipuss. -
not sure if it was the discs or Nero, but Imageburn with TDK's worked fine.
Thanks again!winxp - 3.06 -
IE8 logs me off after I close the browser
By jyeh74 in forum ComputerReplies: 1Last Post: 24th May 2011, 08:03 -
Please look at these Imgburn logs to see why bad burn
By jimdagys in forum DVD RippingReplies: 4Last Post: 18th Dec 2008, 23:27 -
How to print out logs in Outlook Express
By Scooter_NJ in forum ComputerReplies: 6Last Post: 5th Dec 2008, 20:59 -
IP logs and look up
By rubberman in forum ComputerReplies: 12Last Post: 8th Mar 2008, 14:37 -
Logs on my PC vs Privacy and Consent
By videobread in forum Newbie / General discussionsReplies: 9Last Post: 13th Nov 2007, 21:30
