				Results 1 to 15 of 15
	Hmm..strange..All is working fine here..Toast, Perian and 10.5.1...I'm not exactly sure how Perian can make troubles to burning...
	hi serbian,
 i have several mac's, all with perian, after uninstall trough the prefs pane no burning problems ..
 i was so despair, that i bought an external usb dvd burner, in this configuration i had NO problems even with perian installed, funny !?
	Uninstall everything from Divx. My system was unstable since I upgraded to Leopard and I found out I got some remnent of Divx encoder installed (I had previously removed Divx decoder). After all things called Divx were removed, everything work like a charm. Perian has been my decoder of choice for more than a year without any problems with Toast or anything else.
	I'm third on this and I'm sorry but I'm calling B*llsh*t.
 I've burned two discs today, both Verbatim DVD+R DL discs,
 using Toast 8.03 with Perian 1.0 installed on an external FW burner,
 from four divx files, and they built and burned fine without fail, on a MBP
 running 10.5.1 leopard. WIth the Toast DIVX components installed.
 Perian 1.0 is robust and does it's job.
 As i asked you in the other post what it was that you trying to burn to disc,
 sascha h-k, this is REALLY SUSPECT. If anything, I'd suspect your
 Leopard install over Perian. Your, not according to the post, using
 DIVX files, but instead are using ripped DVD output from an outdated
 version of MTR ( 2.66).
 If you have read any posts regarding Leopard, the main thing everyone
 says is that Upgrade and Install is a bad deal, and can cause things
 that worked under Tiger to not work right under Leopard.
 My reccomendation would have been to try a clean install of Leopard
 onto your MBP, and then try again. Then, try upgrading your MTR
 to the current version and get better, concise ripped output from
 a Leopard compatible version of MTR.
 The toast board is full of posts where Perian is RECCOMMENDED
 to handle avi transcoding in MANY cases. We highly reccomened
 it here to facilitate in a wide range of transcoding many
 hard to play files ( mkv, flv).
 I'm sorry...and you may think you found the answer....
 but it's HIGHLY suspect.
 If Perian 1.0 was suspect, as many of us use it,
 it would have been more widely reported as a problem.
 The fact you aren't using DIVX files
 trying to transcode them, that also raises a red flag.
 And MTR 2.66....MTR is up to 3.0.14 ver. M.
 And searching the MTR boards, lots of German release DVDs
 aren't compatible with MTR 2.66...but are in the newest version.
 Also, you didn't post what type of DVD +R DL Media you were using...
 anything not VERBATIM would also be suspect.....
 but not as supsect as the old MTR and a bad Leopard install....."Everyone has to learn, so that they can one day teach."
 When I'm not here, Where can I be found?
 Urban Mac User
	But in the other posting you said:Originally Posted by sascha h-k
 If your happy with your "theory" good luck then...but there is no "BEWARE of Perian"Originally Posted by sascha h-k
 issue, because your the only one experiencing it.
 Everyone else is running Perian and Toast with no problems."Everyone has to learn, so that they can one day teach."
 Urban Mac User
	There was an early release of Perian that caused grief for Toast. It was quickly replaced by the perian developer. So some people could have a problem with Perian that is fixed by downloading and replacing it with the current download -- even if they have the same version numbers.
 The codec that gives Toast nightmares is Xvid. Trash it and stick with Perian.
	from the Perian website:
 Perian enables QuickTime application support for additional Media Types:
 AVI, FLV, and MKV file formats
 MS-MPEG4 v1 & v2, DivX, 3ivX, H.264, FLV1, FSV1, VP6, H263I, VP3, HuffYUV, FFVHuff, MPEG1 & MPEG2 Video, Fraps, Windows Media Audio v1 & v2, Flash ADPCM, Xiph Vorbis (in Matroska), MPEG Layer II Audio
 AVI support for: AAC, AC3 Audio, H.264, MPEG4, and VBR MP3
 Subtitle support for SSA and SRT
 Installation and Removal:
 Please consider removing obsolete QuickTime Components: FFusion, Xvid Delegate, 3ivX, DivX, XviD, msmpeg4v1, msmpeg4v2, AviImporter, EX_M4S2, and Casio AVI Importer
 Urban Mac User
	u r welcome! "Everyone has to learn, so that they can one day teach."
 Urban Mac User
  Possible issues with QuickTime 7.5 & PerianBy ffooky in forum MacReplies: 4Last Post: 11th Jun 2008, 14:27
  QT 7.4 - Perian and MPEG2 troublesBy SERBIAN in forum MacReplies: 0Last Post: 16th Jan 2008, 08:17
  Try Perian 1.0 for your mkv conversionsBy BeardFan in forum ffmpegX general discussionReplies: 22Last Post: 18th Sep 2007, 18:43
  Anyone tried new Perian 1.02b Beta?By terryj in forum MacReplies: 5Last Post: 9th Jul 2007, 02:02
  New Perian - 1.0b5By SERBIAN in forum MacReplies: 2Last Post: 17th Jun 2007, 23:07
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
