    indy, in US
    I use Roxio's Easy CD creator Platinum 5
    I am able to burn data and Audio files on to a 700 MB 80 min CD
    However I have problem with burning 67 min, 72 min, 75 min
    on to 80 min blank CDR disks
    VCD files
    Has anyone experienced it?
    Is there a fix
    Indy
  2. get another program easy cd creator is buggy try unlead DVD or nero
  3. I don't know if this is your problem or not, but someone asked a similar question a while ago and I am repeating the answer I gave at that time here:
    "Thanks for mentioning that you are using Sleazy CD Creator 5 Plat. This is the root of your problems. Due to a clever bug in Sleazy, it will refuse to create a VCD greater than 65 minutes without some prodding from you, the user. It would appear that the writers of this program forgot that VCDs are written in a different mode than data discs. It says, "oh, you want to write more than 650M, well this ain't possible." In reality, as stated elsewhere, a 650M data disc holds 740M of music or VCD. Even worse, the Video CD creator doesn't know of the existance of 700M/80minute discs.
    The solution is easy, use the Video CD Creator to make a disc image. Close that program then open the (data) CD Creator. Burn a disc from the image. Works for me everytime."
    See if that helps.
    Dec 2000
    Homebush, NSW, Australia
    I'm using Easy CD Creator 4 deluxe and it works fine. When I burn in VCD mode, I've burnt source files of 796MB to an 80min CDR, and 806MB to 80MB CDRW's. Note that this is without any intro pages, menus, etc, as they will take up space on the disk and reduce the available space for the actual movie.
    The only other thing I can think of is that it might be your burner not being able to do it, but even my old Ricoh 2x does them, so its unlikely.
    Graham
