  1. Sorry if this is a dumb question, but I can't find anything that will work. I recently bought a new laptop and will be doing a lot of video editing on it. My only question is: is there any way to have the power settings turn off the hard disks after 15 mins but not while rendering video or burning a DVD?
  2. Member classfour's Avatar
    The Heartland, United States
    Not that I know of. Unless the machine sees human activity, it will likely go into a power saving state. You could set up different profiles: One for power saving, one for video rendering; and switch between them.
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
    Jun 2004
    Victoria, Australia
    I'm pretty sure the disk timeouts are dependant on disk activity, not general machine usage. I hear the drives I store videos on spin down while I'm web browsing (off the OS drive).
  4. Control Panel => Power Options
    You should have settings for monitor, HD, system standy, hibernate
    If it's a laptop you can change the "power scheme" to "laptop" and it will give you other options
    Note: turning on/off your HD repeatedly is known to reduce the life expectancy. It's the same as any mechanical device like engines etc...
  5. Thanks everyone
    Does that go for external Hard disks as well?
  6. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Are you rendering off batteries?
    You can set different profiles for AC power vs. batteries.
    http://www.kiva.org/about
