I made a few DivX discs, and most of them work fine, but when I try to play some it says "Resolution not supported"
I can't seem to find a list of supported resolutions, anybody have any ideas?
What resolutions doesn't work for you? DivX DVD players doesn't support any HD resolutions(usually anything over ~720x576).
Baldrick is right. Anything above 720x576 won't be supported by your player.
The "576" we include as it's easiest to just right a general rule and this is a PAL type resolution, but exceeding either of the values in 720x576 may be a problem. I am just making these numbers up to give you an example, but your player probably wouldn't play 800x480 video, even though the 480 is less than 576. If you are converting from high definition sources, your problem is that your resolutions are too large. -
Yeah, i got the same message, when i tried to play 800X600 file with my DVP3142.
By the way, do you got this thing with your Philips: https://forum.videohelp.com/topic344036.html -
Originally Posted by Digiface
I don't have the problem mentioned in the link. Then again, here in the USA we don't use SCART. -
Thanks guys! Yeah the resolution was 768x432, I didn't think it would have any trouble with that but I guess I'll just re-size to 704x396.
Oh and sorry about the two topics, I wasn't sure which forum to post it in so I posted in both, but I guess that was a bad idea.
DVD Player that plays Divx (.avi) and (.mp4) files ?
By keith knip in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Oct 2011, 14:12 -
Philips DVDR3505/37recorder plays divx vod ?
By xbill in forum Newbie / General discussionsReplies: 2Last Post: 7th Jul 2009, 21:59 -
mpg plays badly in divx dvd player
By ssalim in forum Video ConversionReplies: 25Last Post: 3rd Apr 2009, 10:39 -
Philips DVP5992 plays AVIs, Divx too large
By strommsarnac in forum DVD & Blu-ray PlayersReplies: 3Last Post: 10th Dec 2008, 22:32 -
Standalone Player plays only 33 mins of the resulting DivX DVD
By penguin74 in forum DVD RippingReplies: 8Last Post: 30th Oct 2007, 17:25
