Hi there,
I have problems with converting my mov file to flv. I was trying to do it through flash 8 software, but the movie doesn't want to play.
Do you know any good software to convert to flv? I just installed ffmpegx, but it doesn't convert to flv - it gives 0 KB files instead.
go to audio and click
INVERSE MAPPING.
But after that I still couldnt get it to look right so good luck
FLV audio out of sync, can't work VirtualDub w/ FLV plugin
By ZantarV in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 11:51 -
Remove WGA 1.2 doesnt work
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 6th Mar 2009, 23:46 -
Problem with artifacts in flv conversion - i.e. converting to flv from avi
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 30th Apr 2008, 22:09 -
Some audio doesnt work
By TheEmperor in forum AudioReplies: 2Last Post: 16th Aug 2007, 09:05 -
Member Status......doesnt work
By electricsguy in forum FeedbackReplies: 14Last Post: 25th Jun 2007, 10:21
