Great unit, but i have one question: What is the max video res that the player will handle through a hard disk over the usb?
I can play SD on divx and avi fine from hard disk, but if, for example, i convert a 1080x720p .mkv file to divx or avi - I only get sound. But the converted file will play fine from the usb drive on the pc, but not when i play the file through the usb on the dv-400.
Or does the 1080x720 file need to be downscaled to SD first? (Which defeats the object of watching HD over the usb anyway).
The software i use is River Past Video Cleaner - which i think is pretty good, as i am only a beginner.
Let me know if any1 has an idea.
[Just a general tip: Formatting the hard disk so that the player will see it is easy, just make sure the FAT32 partition is set as 'Active' not 'logical' by your partitioning software.]
mark
maa@datarecoverysweden.se
	Is it possible that your dvd player doenst like the avi in such a high resolution? I believe i read it somewhere that some dvd players don't support such a high resolution for an .avi ...
 Not really sure about this. My apologies if i'm wrong.
	Your resolution is too high.
 From the FAQ at Pioneer:
 Whats the maximal resolution for DVD/DivX/Xvid
 720x576 (PAL) /720x480 (NTSC).
 http://www.pioneerfaq.info/english/dv400.php?player=DV-400V&question=DivXGoogle is your Friend
  Pioneer DV-3022KVBy azfarhus in forum DVD & Blu-ray PlayersReplies: 11Last Post: 24th Mar 2012, 04:37
  Pioneer DVRBy vcd4me in forum DVD & Blu-ray RecordersReplies: 20Last Post: 25th May 2011, 01:33
  Pioneer DV-F727By captainneek in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Jan 2010, 14:59
  Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognizedBy Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02
  Philips DVP5982 vs. Pioneer DV-400KBy snowverkill in forum DVD & Blu-ray PlayersReplies: 2Last Post: 31st Jul 2007, 20:44
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
