My Samsung dvd r155 has an auto time feature. It does NOT seem to work property. It's supposed to automatically find the time and date from the cablevision cable. My options are limited too: on/off "Auto Time". My "time" keeps on falling behind. I try to re-apply my on/off "Auto Time". Not sure what to do anymore.![]()
On my Samsung recorder you actually need to disconnect power then re connect and after one to afew minutes the time will sync with a station. Notice though if the station that Samsung uses (usually station 2) is not broadcasting any signal you can not get the time and you need to wait untill it broadcasts.
Sincerely Joakim Agren!
Edit .mkv file (split/join) - nothing works "properly"!!!
By The.King in forum EditingReplies: 19Last Post: 11th May 2013, 07:23 -
My DVD Authoring software stopped working and had an "APPCRASH" error
By Blueknight in forum Newbie / General discussionsReplies: 6Last Post: 13th Jul 2011, 23:55 -
"Full Screen" button not working properly
By ironjack in forum Newbie / General discussionsReplies: 2Last Post: 14th Aug 2010, 20:20 -
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 20:01 -
DVD Flick error message "ffmpeg.exe has stopped working"
By stewiegriffin711 in forum Authoring (DVD)Replies: 4Last Post: 17th Aug 2008, 08:20
