HI:
I have the RJtech1500 II for almost 3 years now. But a couple of weeks ago it began to show a malfunction on audio. Everything (and I mean everything, from original DVDs and CDs to MP3, VCDs, DivX, etc) sounds like a ruined speaker. I changed the TV set (so TV speakers are ok), the cables (diff. cables, so cables are ok), the connections (from the recommend stereo RCA connection to front speakers RCA connection, etc). Sounds got crappy anyway you connect teh device.
I do not know what it could be. Maybe a simple thing, maybe the audio chip is corrupted.
Anybody out there have a clue?
To send the machine to a Service Agent is not an option since to buy another machine will cost the same.
It sounds like you've changed all of the external hardware including the cables. Your only other option would be to try a different output (if the player has other audio outputs).
Otherwise, it's time for a replacement.Google is your Friend
RJTech DVD Player Remote Code
By The Monkees in forum DVD & Blu-ray PlayersReplies: 0Last Post: 17th Apr 2010, 16:08 -
Make LG DVX-286 (/ DVX-276) region-free
By joniakaidiot in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Mar 2010, 07:33 -
LG DVX-392H - Nice but problems... or any hacks?
By Drlawgr in forum DVD & Blu-ray PlayersReplies: 3Last Post: 3rd Sep 2008, 14:08 -
rjtech karaoke 1500/1800
By blackrain2008 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Jan 2008, 09:12 -
anyone have info on RJTech RJ-2200DVRX recorder / pvr?
By buzzinhornets in forum DVD & Blu-ray RecordersReplies: 1Last Post: 21st Aug 2007, 18:13
