I have a pixelview pro tv ultra capture card. When I try to capture video using virtualdub, I get no color. I am sure it is a driver problem, but I can't find any updated drivers for this card. The card has a conexant 2388x chipset. My computer has 2mb ram, an amd fx2 5300 cpu, 250 gb hard disk, so I don't believe I am light on power. My motherboard is a GigabyteM61P-S3.
I would appreciate any help . Thanks
oldboy29@camtel.net
				Results 1 to 9 of 9
	Since I am in the USA, I have setup to use NTSC. I had color with this card, but then my computer blew up and I had to change almost everything. I had trouble before until I got spme oyher drivers. Now I can't locate any drivers to update with. When the card worked, it had a good picture, andcaptured all my cable stations with no problems.
	If your PC 'blew up' it could have taken some of the circuitry of your capture card with it.
	It didn't actually fry. One of the posts holding the cpu broke off, so I had to replace the board.cpu and memory.Th capture card worked with color before I did this.
	you need the exact model number of the card, but there are drivers out there if you do a google search. --
	You may simply have a video overlay problem. Play one of your caps in two media players at one time. Are they both black and white?
	using powervcr se ii I get color. With virtualdubI still get black and white.I am set up for ntsc. Where on the card would i find it,s exact number?
 thanks for all the replied-appreciate it.
  PAL Capture Black & WhiteBy SGGS in forum Capturing and VCRReplies: 42Last Post: 9th Dec 2011, 05:12
  PAL Hi8 Capture Black & WhiteBy SGGS in forum MacReplies: 1Last Post: 8th Dec 2011, 10:15
  Black & White Capture w/ Dazzle!By Rowan88 in forum Capturing and VCRReplies: 9Last Post: 12th Mar 2010, 14:42
  ATI 650 capture card: analog channels black&whiteBy lhughes in forum Capturing and VCRReplies: 2Last Post: 3rd Nov 2009, 07:34
  Capture Card,Black and WhiteBy I STANFORD I in forum Capturing and VCRReplies: 8Last Post: 28th Jun 2008, 11:26
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
