hello
iam new on mac and on video. iam french and my english is limited.
i try to use ffmpeg on my new mac and impossible to setup the binaries mencoder, mplayer and mpeg2enc.
it toll me :
The installation was not successful.
WARNING: Improper use of the sudo command could lead to data loss
or the deletion of important system files. Please double-check your
typing when using sudo. Type "man sudo" for more information.
To proceed, enter your password, or type Ctrl-C to abort.
so does ffmpegX 0.0.9x r2 works with OS X 10.5 ?
thank you for your help
florian
It works (with some restrictions/known errors regarding the bitrate buttons). I'm on 10.5.1 and it works fine for me. Be sure to be logged in using an administrator account when installing. If this doesn't help, try copying the binaries manually to Library/Application Support/ffmpegx/
thank you for your help, but i tryed to copy manually to library/application suport/... but the ffmpeg folder doesnt exist.
i tryed to create this folder from ffmpeg but i didnt find the way.
how can i do ???
thanks
Copy ffmpegX.app from the .dmg to your /Applications folder. Launch the app from the new copy. Locate the binaries, enter your password, install. If gives the warning, proceed; the installer needs to do the sudo command to install the binaries.
Make sure your Administrator account has a password, and a 'simple' one (no special characters or spaces). You can change the password temporarily for this installation if you have to; it's only needed at installation time.
See also https://forum.videohelp.com/topic339989.html
ffmpegx?
By creationx in forum MacReplies: 2Last Post: 28th Jul 2010, 12:15 -
FFMPEGx
By AnastasiaM in forum ffmpegX general discussionReplies: 1Last Post: 11th Dec 2009, 12:49 -
FFmpegX help
By Omipower in forum ffmpegX general discussionReplies: 4Last Post: 19th Aug 2008, 11:08 -
ffmpegX help
By delectabledoz in forum ffmpegX general discussionReplies: 2Last Post: 1st Aug 2008, 18:29 -
what about ffmpegx 1.0?
By imp in forum ffmpegX general discussionReplies: 8Last Post: 8th Nov 2007, 11:36
