I just recently discovered this. I am not sure what I have changed or I did not notice this before ?
When I open the file in virtualdub, now I notice that there is a thin bar on the right hand side. I am doing processing using the deshaker which now shows the intermitten black lines ??? I am wondering how I get rid of this ???
I do not remember changing anything. The previous ones I did do not show the black lines on the edges.
BTW, my video source is 640 x 480, and I use the deshaker with HDV format. Is that the best setting ?
Thanks for your upcoming assistance.
Best regards
Results 1 to 14 of 14
It's not uncommon for video files to have black bars or garbage at the edges of the frame.
During the course Deshaker's operation it's normal for borders to appear. So it has options that control to deal with it. -
oh ok.. but my previous few never shown before though ... they are avi files. I wonder if installing codecs might have changed some of it I wonder as I did that yesterday but it was for other programs not virtualdub ??? in fact it was thefilmmachine hmmmm
now it is out of whack !! with ugly black lines on the right side of it .... i am talking about before even doing any processing !!! -
Not likely.Originally Posted by holeepassion
Just use VirtualDub's cropping feature to remove the black border it annoys you.Originally Posted by holeepassion -
when i view using other software there is no black bar !!! so it must have been some of those things oh bummer ... do i need to recutting etc .. more work argggggghhhhhhhhhhhhhhh
i wonder how it would change my aspect ratio .. i think it changed it .. oh more issues then !!!
What other software? Some media players will simulate television's overscan and will hide the outer ~5% of the frame.Originally Posted by holeepassion
Post a screen shot from VirtualDub or a short segment of the AVI file and I'll look at it. -
oh i see ... wonder how the blackie suddently appear though . it wasnt there for the past few days ....
windows player classic ....
i am confused how now .. it means that the aspect ratio is not true 640 x 480 then ... if that is the case with the extra black line -
when i cropped i got those colours on the top .. oh nooooooooooooooooooooooooo
i think i have to reinstall some stuff -
that is right .... i have tried different files etc etc ... just restore before i adding some codecs etc . now it is back to normal now ... phew ....
but i have to reinstall the stuff i need for later processing so much hassle ... wonder where i could locate dell restore files so that i dont have to do that all over again ???
anybody >>>> -
I still wonder what is causing it so that I can disable that particular one
Hmmm any ideas ??? -
I've see this problem for the first time. I'm not use to work with ffdshow codecs pack i preffer work with xvid codecs pack.
If your video source has been encpoded with a ffdeshow have this problem (i don know why).
Reencode the video source with xvid one passed and fix the problem.
greetings!
How can I join two sided dvds.......................?
By forest.lawn in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2011, 18:51 -
Help with audio in bar please
By theflame01 in forum AudioReplies: 0Last Post: 30th Apr 2010, 05:21 -
ffmpeg seek bar (or timing bar)
By Seven40Rob in forum ffmpegX general discussionReplies: 1Last Post: 7th Oct 2008, 23:36 -
green vertical bar on left, purple verticle bar on right, source B&W VH
By lipwak in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jul 2008, 21:29 -
Double sided discs
By brainoverload in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2008, 10:15
