Results 1 to 12 of 12
    Apr 2006
    Is there a command line tool available that would allow me to Re-Encode the audio of a video and output it in that format?
    Now I know FFMpeg and MPlayer would allow me to output the audio in its present form inside the container like so:
    mplayer input.avi -dumpaudio -dumpfile output.ac3
    ffmpeg -i input.avi -vn -acodec copy input.ac3
    Scenario
    AVI File
    MP3 Audio
    Could I use one of the above tools to output a Re-Encoded AC3 or MP2 or some other format based on the aforementioned scenario? Basically Re-Encode the audio and output it. Kind of like Demuxing/Re-Encoding at the same time?
  2. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Both ffmpeg and Besweet have GUIs which expose the command lines which you can copy and modify.
    For example, using ffmeg, this batch file will extract the audio from an avi (or all avis in a folder) and produce an AC3 at 128k:
    save as AVI-MAKE-AC3.BAT
    @echo avi-make-ac3 file.avi
    @echo convert avi to ac3, 128k
    @if %1X==X goto ALL
    :LOOP
    for %%I in (%1) do  p:\ffmpeggui\ffmpeg -i "%%~fI" -ab 128 -ar 48000 -ac 2 -acodec ac3 -y "%%~dpnI.ac3"
    SHIFT
    @if %1X==X goto END
    @goto LOOP
    :ALL
    for %%I in (*.avi) do  p:\ffmpeggui\ffmpeg -i "%%~fI" -ab 128 -ar 48000 -ac 2 -acodec ac3 -y "%%~dpnI.ac3"
    :END
    Apr 2006
    Alan, thanks for responding.
    A couple of questions.
    1) I am assuming Mplayer/Mencoder cannot do what I asked?
    2) I don't have FFMpeg and I have been trying to download it, I don't see where to download it with the link below:
    http://ffmpeg.mplayerhq.hu/
    I hit the "Download and SVN" link, but didn't see anything there.
    3) I have Beesweet 1.4. It seems like Besweet has to have audio input to spit out the audio output. Meaning, you cannot give it an avi as input and it spits out the audio.
    Like always, I will continue to look for these answers
    Apr 2006
    AlanHk, disregard #2, I went to the 2nd mirror and downloaded the exe, although it isnt the gui.
    Apr 2006
    Just by eyeballing this command line, does anyone see a problem?
    ffmpeg.exe -i "C:\input.avi" -ab 128 -ar 48000 -ac 2 -acodec ac3 -y "C:\input.ac3"
    I am knew to ffmpeg, so I am testing something simple and it kind of tells me that there maybe something wrong with the paramaters entered and I have tried it on different video inputs.
  6. Banned
    Freedonia
    You are correct, but that's why demuxing exists. I'm not sure I'd trust "dumping" the audio AND converting it on the fly to give the best results.
    There are generally 2 ways to do things in the video/audio world - quickly or correctly. They aren't the same. If you just want it done quickly, then you agree to live with weird problems that may crop up. If you want it done correctly, then you demux the audio before you work on it and it takes as long as it takes to work correctly.-
  7. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    You are correct
    No, he's incorrect.
    It works fine.
    I used to use BeSweet's wizard in batch mode, throw in a folder full of AVIs and get matching AC3s.
    The command line it makes is something like:
    "P:\BeSweet\BeSweet\BeSweet.exe" -core( -input "P:\A1.avi" -output "P:\A1 - New - [12.01.2008] - [20.46.56].ac3" -logfilea "P:\BeSweet\BeSweet.log" ) -ssrc( --rate 48000 ) -ac3enc( -b 128 )
    Which you can use as a basis of your own batch file.
    These days though I usually do demux to MP3, so I can run MP3Gain, then batch convert with an ffmpeg command line.
    And if I've been doing any editing (trims) in AVS files, I use WAVI to extract from AVS to wave and convert that.
  8. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    I don't use those, can't say.
    What do you mean " it kind of tells me that there maybe something wrong "?
    Anyway, looks okay -- as long as ffmpeg is in the command path. If not, give the full path of the EXE.
    You can get the GUI here: ffmpeggui
    Apr 2006
    Thanks for the reply Alan.
    I was literally up at 2 AM this mourning fooling around with alot of this stuff and incorporating it into my .Net application that streamlines encoding.
    There was and error in FFMpeg because I didn't have a "k" next to the 128 in this argument "-ab 128".
    I have some other questions, but I will probably have to make a new thread.
  10. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    That's odd, because my batch files work without the "k"
    According to the help:
    -ab bitrate set audio bitrate (in kbit/s)
    This is for "ffmpeg version 0.4.9-pre1, build 4743"
    But I see the docs at http://ffmpeg.mplayerhq.hu/ffmpeg-doc.html
    say: `-ab bitrate' Set the audio bitrate in bit/s (default = 64k).
    I can't see which build this is for.
    So perhaps they have changed that. If so seems a bit inconsiderate to change an option that will screw up existing batch files and GUIs.
    Apr 2006
    Not sure what command to use to see what build I have.
    I downloaded FFMpeg from the link below:
    http://ffdshow.faireal.net/mirror/ffmpeg/
    I choose the first one at the top
  12. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Just type "ffmpeg" and it gives its help. Redirect to a file:
    ffmpeg >ffmpeg.txt
    That lists (from the one at your link):
    usage: ffmpeg [[infile options] -i infile]... {[outfile options] outfile}...
    Hyper fast Audio and Video encoder
    Main options:
    -L                  show license
    -h                  show help
    -version            show version
    -formats            show available formats, codecs, protocols, ...
    -f fmt              force format
    -i filename         input file name
    -y                  overwrite output files
    -t duration         record or transcode "duration" seconds of audio/video
    -fs limit_size      set the limit file size in bytes
    -ss time_off        set the start time offset
    -itsoffset time_off  set the input ts offset
    -title string       set the title
    -timestamp time     set the timestamp
    -author string      set the author
    -copyright string   set the copyright
    -comment string     set the comment
    -album string       set the album
    -v verbose          control amount of logging
    -target type        specify target file type ("vcd", "svcd", "dvd", "dv", "dv50", "pal-vcd", "ntsc-svcd", ...)
    -dframes number     set the number of data frames to record
    -sn                 disable subtitle
    -scodec codec       force subtitle codec ('copy' to copy stream)
    -newsubtitle        add a new subtitle stream to the current output stream
    -slang code         set the ISO 639 language code (3 letters) of the current subtitle stream
    Video options:
    -b                  set bitrate (in bits/s)
    -vb                 set bitrate (in bits/s)
    -vframes number     set the number of video frames to record
    -r rate             set frame rate (Hz value, fraction or abbreviation)
    -s size             set frame size (WxH or abbreviation)
    -aspect aspect      set aspect ratio (4:3, 16:9 or 1.3333, 1.7777)
    -croptop size       set top crop band size (in pixels)
    -cropbottom size    set bottom crop band size (in pixels)
    -cropleft size      set left crop band size (in pixels)
    -cropright size     set right crop band size (in pixels)
    -padtop size        set top pad band size (in pixels)
    -padbottom size     set bottom pad band size (in pixels)
    -padleft size       set left pad band size (in pixels)
    -padright size      set right pad band size (in pixels)
    -padcolor color     set color of pad bands (Hex 000000 thru FFFFFF)
    -vn                 disable video
    -vcodec codec       force video codec ('copy' to copy stream)
    -sameq              use same video quality as source (implies VBR)
    -pass n             select the pass number (1 or 2)
    -passlogfile file   select two pass log file name
    -newvideo           add a new video stream to the current output stream
    Advanced Video options:
    -pix_fmt format     set pixel format, 'list' as argument shows all the pixel formats supported
    -intra              use only intra frames
    -vdt n              discard threshold
    -qscale q           use fixed video quantizer scale (VBR)
    -qdiff q            max difference between the quantizer scale (VBR)
    -rc_override override  rate control override for specific intervals
    -me_threshold       motion estimaton threshold
    -strict strictness  how strictly to follow the standards
    -deinterlace        deinterlace pictures
    -psnr               calculate PSNR of compressed frames
    -vstats             dump video coding statistics to file
    -vstats_file file   dump video coding statistics to file
    -intra_matrix matrix  specify intra matrix coeffs
    -inter_matrix matrix  specify inter matrix coeffs
    -top                top=1/bottom=0/auto=-1 field first
    -dc precision       intra_dc_precision
    -vtag fourcc/tag    force video tag/fourcc
    -qphist             show QP histogram
    -vbsf bitstream filter
    Audio options:
    -ab                 set bitrate (in bits/s)
    -aframes number     set the number of audio frames to record
    -aq quality         set audio quality (codec-specific)
    -ar rate            set audio sampling rate (in Hz)
    -ac channels        set number of audio channels
    -an                 disable audio
    -acodec codec       force audio codec ('copy' to copy stream)
    -vol volume         change audio volume (256=normal)
    -newaudio           add a new audio stream to the current output stream
    -alang code         set the ISO 639 language code (3 letters) of the current audio stream
    Advanced Audio options:
    -atag fourcc/tag    force audio tag/fourcc
    -absf bitstream filter
    Subtitle options:
    Audio/Video grab options:
    -vc channel         set video grab channel (DV1394 only)
    -tvstd standard     set television standard (NTSC, PAL (SECAM))
    -isync              sync read on input
    Advanced options:
    -map file:stream[:syncfile:syncstream]  set input stream mapping
    -map_meta_data outfile:infile  set meta data information of outfile from infile
    -benchmark          add timings for benchmarking
    -dump               dump each input packet
    -hex                when dumping packets, also dump the payload
    -re                 read input at native frame rate
    -loop_input         loop (current only works with images)
    -loop_output        number of times to loop output in formats that support looping (0 loops forever)
    -threads count      thread count
    -vsync              video sync method
    -async              audio sync method
    -adrift_threshold   audio drift threshold
    -vglobal            video global header storage type
    -copyts             copy timestamps
    -shortest           finish encoding within shortest input
    -dts_delta_threshold   timestamp discontinuity delta threshold
    -programid          desired program number
    -muxdelay seconds   set the maximum demux-decode delay
    -muxpreload seconds  set the initial demux-decode delay
    AVCodecContext AVOptions:
    -b                 <int>   E.V.. set bitrate (in bits/s)
    -ab                <int>   E..A. set bitrate (in bits/s)
    -bt                <int>   E.V.. set video bitrate tolerance (in bits/s)
    -flags             <flags> EDVA.
       mv4                     E.V.. use four motion vector by macroblock (mpeg4)
       obmc                    E.V.. use overlapped block motion compensation (h263+)
       qpel                    E.V.. use 1/4 pel motion compensation
       loop                    E.V.. use loop filter
       gmc                     E.V.. use gmc
       mv0                     E.V.. always try a mb with mv=<0,0>
       part                    E.V.. use data partitioning
       gray                    EDV.. only decode/encode grayscale
       psnr                    E.V.. error[?] variables will be set during encoding
       naq                     E.V.. normalize adaptive quantization
       ildct                   E.V.. use interlaced dct
       low_delay               EDV.. force low delay
       alt                     E.V.. enable alternate scantable (mpeg2/mpeg4)
       trell                   E.V.. use trellis quantization
       bitexact                EDVAS use only bitexact stuff (except (i)dct)
       aic                     E.V.. h263 advanced intra coding / mpeg4 ac prediction
       umv                     E.V.. use unlimited motion vectors
       cbp                     E.V.. use rate distortion optimization for cbp
       qprd                    E.V.. use rate distortion optimization for qp selection
       aiv                     E.V.. h263 alternative inter vlc
       slice                   E.V..
       ilme                    E.V.. interlaced motion estimation
       scan_offset             E.V.. will reserve space for svcd scan offset user data
       cgop                    E.V.. closed gop
    -me_method         <int>   E.V.. set motion estimation method
       zero                    E.V.. zero motion estimation (fastest)
       full                    E.V.. full motion estimation (slowest)
       epzs                    E.V.. EPZS motion estimation (default)
       log                     E.V.. log motion estimation
       phods                   E.V.. phods motion estimation
       x1                      E.V.. X1 motion estimation
       hex                     E.V.. hex motion estimation
       umh                     E.V.. umh motion estimation
       iter                    E.V.. iter motion estimation
    -me                <int>   E.V.. set motion estimation method (deprecated, use me_method instead)
    -g                 <int>   E.V.. set the group of picture size
    -cutoff            <int>   E..A. set cutoff bandwidth
    -frame_size        <int>   E..A.
    -qcomp             <float> E.V.. video quantizer scale compression (VBR)
    -qblur             <float> E.V.. video quantizer scale blur (VBR)
    -qmin              <int>   E.V.. min video quantizer scale (VBR)
    -qmax              <int>   E.V.. max video quantizer scale (VBR)
    -qdiff             <int>   E.V.. max difference between the quantizer scale (VBR)
    -bf                <int>   E.V.. use 'frames' B frames
    -b_qfactor         <float> E.V.. qp factor between p and b frames
    -rc_strategy       <int>   E.V.. ratecontrol method
    -b_strategy        <int>   E.V.. strategy to choose between I/P/B-frames
    -hurry_up          <int>   .DV..
    -ps                <int>   E.V.. rtp payload size in bits
    -bug               <flags> .DV.. workaround not auto detected encoder bugs
       autodetect              .DV..
       old_msmpeg4             .DV.. some old lavc generated msmpeg4v3 files (no autodetection)
       xvid_ilace              .DV.. Xvid interlacing bug (autodetected if fourcc==XVIX)
       ump4                    .DV.. (autodetected if fourcc==UMP4)
       no_padding              .DV.. padding bug (autodetected)
       amv                     .DV..
       ac_vlc                  .DV.. illegal vlc bug (autodetected per fourcc)
       qpel_chroma             .DV..
       std_qpel                .DV.. old standard qpel (autodetected per fourcc/version)
       qpel_chroma2            .DV..
       direct_blocksize         .DV.. direct-qpel-blocksize bug (autodetected per fourcc/version)
       edge                    .DV.. edge padding bug (autodetected per fourcc/version)
       hpel_chroma             .DV..
       dc_clip                 .DV..
       ms                      .DV.. workaround various bugs in microsofts broken decoders
    -lelim             <int>   E.V.. single coefficient elimination threshold for luminance (negative values also consider dc coefficient)
    -celim             <int>   E.V.. single coefficient elimination threshold for chrominance (negative values also consider dc coefficient)
    -strict            <int>   .DVA. how strictly to follow the standards
       very                    E.V.. strictly conform to a older more strict version of the spec or reference software
       strict                  E.V.. strictly conform to all the things in the spec no matter what consequences
       normal                  E.V..
       inofficial              E.V.. allow inofficial extensions
       experimental            E.V.. allow non standardized experimental things
    -b_qoffset         <float> E.V.. qp offset between p and b frames
    -er                <int>   .DVA. set error resilience strategy
       careful                 .DV..
       compliant               .DV..
       aggressive              .DV..
       very_aggressive         .DV..
    -mpeg_quant        <int>   E.V.. use MPEG quantizers instead of H.263
    -qsquish           <float> E.V.. how to keep quantizer between qmin and qmax (0 = clip, 1 = use differentiable function)
    -rc_qmod_amp       <float> E.V.. experimental quantizer modulation
    -rc_qmod_freq      <int>   E.V.. experimental quantizer modulation
    -rc_eq             <string> E.V.. set rate control equation
    -maxrate           <int>   E.V.. set max video bitrate tolerance (in bits/s)
    -minrate           <int>   E.V.. set min video bitrate tolerance (in bits/s)
    -bufsize           <int>   E.V.. set ratecontrol buffer size (in bits)
    -rc_buf_aggressivity <float> E.V.. currently useless
    -i_qfactor         <float> E.V.. qp factor between p and i frames
    -i_qoffset         <float> E.V.. qp offset between p and i frames
    -rc_init_cplx      <float> E.V.. initial complexity for 1-pass encoding
    -dct               <int>   E.V.. DCT algorithm
       auto                    E.V.. autoselect a good one (default)
       fastint                 E.V.. fast integer
       int                     E.V.. accurate integer
       mmx                     E.V..
       mlib                    E.V..
       altivec                 E.V..
       faan                    E.V.. floating point AAN DCT
    -lumi_mask         <float> E.V.. compresses bright areas stronger than medium ones
    -tcplx_mask        <float> E.V.. temporal complexity masking
    -scplx_mask        <float> E.V.. spatial complexity masking
    -p_mask            <float> E.V.. inter masking
    -dark_mask         <float> E.V.. compresses dark areas stronger than medium ones
    -idct              <int>   EDV.. select IDCT implementation
       auto                    EDV..
       int                     EDV..
       simple                  EDV..
       simplemmx               EDV..
       libmpeg2mmx             EDV..
       ps2                     EDV..
       mlib                    EDV..
       arm                     EDV..
       altivec                 EDV..
       sh4                     EDV..
       simplearm               EDV..
       simplearmv5te           EDV..
       h264                    EDV..
       vp3                     EDV..
       ipp                     EDV..
       xvidmmx                 EDV..
    -ec                <flags> .DV.. set error concealment strategy
       guess_mvs               .DV.. iterative motion vector (MV) search (slow)
       deblock                 .DV.. use strong deblock filter for damaged MBs
    -pred              <int>   E.V.. prediction method
       left                    E.V..
       plane                   E.V..
       median                  E.V..
    -aspect            <rational> E.V.. sample aspect ratio
    -debug             <flags> EDVAS print specific debug info
       pict                    .DV.. picture info
       rc                      E.V.. rate control
       bitstream               .DV..
       mb_type                 .DV.. macroblock (MB) type
       qp                      .DV.. per-block quantization parameter (QP)
       mv                      .DV.. motion vector
       dct_coeff               .DV..
       skip                    .DV..
       startcode               .DV..
       pts                     .DV..
       er                      .DV.. error resilience
       mmco                    .DV.. memory management control operations (H.264)
       bugs                    .DV..
       vis_qp                  .DV.. visualize quantization parameter (QP), lower QP are tinted greener
       vis_mb_type             .DV.. visualize block types
    -vismv             <int>   .DV.. visualize motion vectors (MVs)
       pf                      .DV.. forward predicted MVs of P-frames
       bf                      .DV.. forward predicted MVs of B-frames
       bb                      .DV.. backward predicted MVs of B-frames
    -mb_qmin           <int>   E.V.. obsolete, use qmin
    -mb_qmax           <int>   E.V.. obsolete, use qmax
    -cmp               <int>   E.V.. full pel me compare function
       sad                     E.V.. sum of absolute differences, fast (default)
       sse                     E.V.. sum of squared errors
       satd                    E.V.. sum of absolute Hadamard transformed differences
       dct                     E.V.. sum of absolute DCT transformed differences
       psnr                    E.V.. sum of squared quantization errors (avoid, low quality)
       bit                     E.V.. number of bits needed for the block
       rd                      E.V.. rate distortion optimal, slow
       zero                    E.V.. 0
       vsad                    E.V.. sum of absolute vertical differences
       vsse                    E.V.. sum of squared vertical differences
       nsse                    E.V.. noise preserving sum of squared differences
       w53                     E.V.. 5/3 wavelet, only used in snow
       w97                     E.V.. 9/7 wavelet, only used in snow
       dctmax                  E.V..
       chroma                  E.V..
    -subcmp            <int>   E.V.. sub pel me compare function
       zero                    E.V.. 0
       dctmax                  E.V..
       chroma                  E.V..
    -mbcmp             <int>   E.V.. macroblock compare function
       zero                    E.V.. 0
       dctmax                  E.V..
       chroma                  E.V..
    -ildctcmp          <int>   E.V.. interlaced dct compare function
       zero                    E.V.. 0
       dctmax                  E.V..
       chroma                  E.V..
    -dia_size          <int>   E.V.. diamond type & size for motion estimation
    -last_pred         <int>   E.V.. amount of motion predictors from the previous frame
    -preme             <int>   E.V.. pre motion estimation
    -precmp            <int>   E.V.. pre motion estimation compare function
       zero                    E.V.. 0
       dctmax                  E.V..
       chroma                  E.V..
    -pre_dia_size      <int>   E.V.. diamond type & size for motion estimation pre-pass
    -subq              <int>   E.V.. sub pel motion estimation quality
    -me_range          <int>   E.V.. limit motion vectors range (1023 for DivX player)
    -ibias             <int>   E.V.. intra quant bias
    -pbias             <int>   E.V.. inter quant bias
    -coder             <int>   E.V..
       vlc                     E.V.. variable length coder / huffman coder
       ac                      E.V.. arithmetic coder
       raw                     E.V.. raw (no encoding)
       rle                     E.V.. run-length coder
       deflate                 E.V.. deflate-based coder
    -context           <int>   E.V.. context model
    -mbd               <int>   E.V.. macroblock decision algorithm (high quality mode)
       simple                  E.V.. use mbcmp (default)
       bits                    E.V.. use fewest bits
       rd                      E.V.. use best rate distortion
    -sc_threshold      <int>   E.V.. scene change threshold
    -lmin              <int>   E.V.. min lagrange factor (VBR)
    -lmax              <int>   E.V.. max lagrange factor (VBR)
    -nr                <int>   E.V.. noise reduction
    -rc_init_occupancy <int>   E.V.. number of bits which should be loaded into the rc buffer before decoding starts
    -inter_threshold   <int>   E.V..
    -flags2            <flags> EDVA.
       fast                    E.V.. allow non spec compliant speedup tricks
       sgop                    E.V.. strictly enforce gop size
       noout                   E.V.. skip bitstream encoding
       local_header            E.V.. place global headers at every keyframe instead of in extradata
       bpyramid                E.V.. allows B-frames to be used as references for predicting
       wpred                   E.V.. weighted biprediction for b-frames (H.264)
       mixed_refs              E.V.. one reference per partition, as opposed to one reference per macroblock
       dct8x8                  E.V.. high profile 8x8 transform (H.264)
       fastpskip               E.V.. fast pskip (H.264)
       aud                     E.V.. access unit delimiters (H.264)
       brdo                    E.V.. b-frame rate-distortion optimization
       skiprd                  E.V.. RD optimal MB level residual skipping
       ivlc                    E.V.. intra vlc table
       drop_frame_timecode         E.V..
       non_linear_q            E.V.. use non linear quantizer
    -error             <int>   E.V..
    -antialias         <int>   .DV.. MP3 antialias algorithm
       auto                    .DV..
       fastint                 .DV..
       int                     .DV..
       float                   .DV..
    -qns               <int>   E.V.. quantizer noise shaping
    -threads           <int>   EDV..
    -mb_threshold      <int>   E.V.. macroblock threshold
    -dc                <int>   E.V.. intra_dc_precision
    -nssew             <int>   E.V.. nsse weight
    -skip_top          <int>   .DV.. number of macroblock rows at the top which are skipped
    -skip_bottom       <int>   .DV.. number of macroblock rows at the bottom which are skipped
    -profile           <int>   E.VA.
       unknown                 E.VA.
       aac_main                E..A.
       aac_low                 E..A.
       aac_ssr                 E..A.
       aac_ltp                 E..A.
    -level             <int>   E.VA.
       unknown                 E.VA.
    -lowres            <int>   .DV.. decode at 1= 1/2, 2=1/4, 3=1/8 resolutions
    -skip_threshold    <int>   E.V.. frame skip threshold
    -skip_factor       <int>   E.V.. frame skip factor
    -skip_exp          <int>   E.V.. frame skip exponent
    -skipcmp           <int>   E.V.. frame skip compare function
       zero                    E.V.. 0
       dctmax                  E.V..
       chroma                  E.V..
    -border_mask       <float> E.V.. increases the quantizer for macroblocks close to borders
    -mblmin            <int>   E.V.. min macroblock lagrange factor (VBR)
    -mblmax            <int>   E.V.. max macroblock lagrange factor (VBR)
    -mepc              <int>   E.V.. motion estimation bitrate penalty compensation (1.0 = 256)
    -bidir_refine      <int>   E.V.. refine the two motion vectors used in bidirectional macroblocks
    -brd_scale         <int>   E.V.. downscales frames for dynamic B-frame decision
    -crf               <float> E.V.. enables constant quality mode, and selects the quality (x264)
    -cqp               <int>   E.V.. constant quantization parameter rate control method
    -keyint_min        <int>   E.V.. minimum interval between IDR-frames (x264)
    -refs              <int>   E.V.. reference frames to consider for motion compensation (Snow)
    -chromaoffset      <int>   E.V.. chroma qp offset from luma
    -bframebias        <int>   E.V.. influences how often B-frames are used
    -trellis           <int>   E.VA. rate-distortion optimal quantization
    -directpred        <int>   E.V.. direct mv prediction mode - 0 (none), 1 (spatial), 2 (temporal)
    -complexityblur    <float> E.V.. reduce fluctuations in qp (before curve compression)
    -deblockalpha      <int>   E.V.. in-loop deblocking filter alphac0 parameter
    -deblockbeta       <int>   E.V.. in-loop deblocking filter beta parameter
    -partitions        <flags> E.V.. macroblock subpartition sizes to consider
       parti4x4                E.V..
       parti8x8                E.V..
       partp4x4                E.V..
       partp8x8                E.V..
       partb8x8                E.V..
    -sc_factor         <int>   E.V.. multiplied by qscale for each frame and added to scene_change_score
    -mv0_threshold     <int>   E.V..
    -b_sensitivity     <int>   E.V.. adjusts sensitivity of b_frame_strategy 1
    -compression_level <int>   E.VA.
    -use_lpc           <int>   E..A. sets whether to use LPC mode (FLAC)
    -lpc_coeff_precision <int>   E..A. LPC coefficient precision (FLAC)
    -min_prediction_order <int>   E..A.
    -max_prediction_order <int>   E..A.
    -prediction_order_method <int>   E..A. search method for selecting prediction order
    -min_partition_order <int>   E..A.
    -max_partition_order <int>   E..A.
    -timecode_frame_start <int>   E.V.. GOP timecode frame start number, in non drop frame format
    -request_channels  <int>   .D.A. set desired number of audio channels
    AVFormatContext AVOptions:
    -probesize         <int>   .D...
    -muxrate           <int>   E.... set mux rate
    -packetsize        <int>   E.... set packet size
    -fflags            <flags> ED...
       ignidx                  .D... ignore index
       genpts                  .D... generate pts
    -track             <int>   E....  set the track number
    -year              <int>   E.... set the year
    -analyzeduration   <int>   .D... how many microseconds are analyzed to estimate duration
    SWScaler AVOptions:
    -sws_flags         <flags> E.V.. scaler/cpu flags
       fast_bilinear           E.V.. fast bilinear
       bilinear                E.V.. bilinear
       bicubic                 E.V.. bicubic
       experimental            E.V.. experimental
       neighbor                E.V.. nearest neighbor
       area                    E.V.. averaging area
       bicublin                E.V.. luma bicubic, chroma bilinear
       gauss                   E.V.. gaussian
       sinc                    E.V.. sinc
       lanczos                 E.V.. lanczos
       spline                  E.V.. natural bicubic spline
       print_info              E.V.. print info
       accurate_rnd            E.V.. accurate rounding
       mmx                     E.V.. MMX SIMD acceleration
       mmx2                    E.V.. MMX2 SIMD acceleration
       3dnow                   E.V.. 3DNOW SIMD acceleration
       altivec                 E.V.. AltiVec SIMD acceleration
       bfin                    E.V.. Blackfin SIMD acceleration
       full_chroma_int         E.V.. full chroma interpolation
       full_chroma_inp         E.V.. full chroma input
    And the above options do indeed say :
    And we see "-version ".
    trying "ffmpeg -version" gives
    FFmpeg SVN-r11143
    Not sure how that relates to "my" version (which came packaged with ffmpeggui), but it's different.
    Not a great idea, as I said, to change how a command line switch works between minor updates. I can't update the version with ffmpeggui with this incompatibility.
