Hello,
I have a FLV file, and I would like to extract the audio from it into in MP3, is that possible?
Thanks,
AlanAlan
	Here another FREE and SIMPLE solution to convert FLV to WAV or MP3 at once with Db gains
 1) REQUIREMENTS 1
 you must have FFDSHOW installed
 I personally recommend CCCP
 http://www.cccp-project.net/
 just install
 2) REQUIREMENTS 2
 You must configure FFDSHOW enabling FLV1 decoding
 like this :
 - menu START
 - Combined Community Codec Pack
 - Filters
 - FFDSHOW Video Decoder Configuration
 enable FLV1, see image bellow
 http://img212.imageshack.us/img212/2355/codecai0.jpg
 3) REQUIREMENT 3
 Install AVISYNTH
 4) INSTALL some already made scripts
 http://avi2iso.planetaclix.pt/youtube.rar
 UnRAR to a ROOT FOLDER, it will create a YOUTUBE FOLDER
 5) RUN SETUP.BAT
 this will register FLV playback in your system
 6) CONVERTING
 copy your FLV file into YOUTUBE FOLDER and RENAME IT to VIDEO.FLV
 YOU MUST RENAME IT TO VIDEO.FLV
 EXECUTE
 flv2mp3.bat
 By this time you must be able to play any FLV in WMP, and convert to MP3 and WAV
 Hope this helps
	An easier way to do it would be to use FLV Extract. It'll extract the FLV's streams into an MP3 audio stream, an AVI video stream, and a timecode file (that last one, if I remember correctly). If cameras add ten pounds, why would people want to eat them?
  Compress large FLV file to a smaller size FLV fileBy RustyBob in forum Video ConversionReplies: 1Last Post: 26th Oct 2011, 18:21
  Multiple FLV files into 1 big FLV file, how??By vividbreeze in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2008, 16:11
  How to merge audio file(mp3) and a video file (flv)By suresh3484 in forum Video Streaming DownloadingReplies: 0Last Post: 20th May 2008, 01:15
  question about converting flv file to regular avi type of fileBy jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 12:39
  How do I compress a large .FLV file to a smaller .FLV fileBy goheadtry in forum Newbie / General discussionsReplies: 2Last Post: 8th Aug 2007, 01:13
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
