every dvd i make at the moment has no audio....i tested the files there is audio there but when put in a stand alone dvd player there is never any audio
the files play fine other than no audio.....all settings in dvd lab are set my my area being PAL....all files are PAL Mpeg2 but no audio at play back and no idea why if anyone can help please
What is your audio file format?
It should be AC3 (most common), LPCM (large file) all 48 kHz sampling rate.
When you import into DVD Lab asset bin it will ask you to demux your file, do that and you can see audio format.
Also recommended procedure for proper compile.
Check this site for more details on authoring.
http://www.digitalfaq.com/dvdguides/authorburn/intro.htm -
mpeg2 audio (mpeg1 layer2) is perfectly legal for PAL playback, as is AC3, LPCM and DTS.
What audio are you using ?
Do you get audio when you test on your PC ?
Do you have menus ? If so, do they have the same format audio as your other assets ?Read my blog here.
DVD-lab Pro advice for two audio trasks
By blajko in forum Authoring (DVD)Replies: 0Last Post: 20th Jul 2010, 01:33 -
DVD Lab Pro Audio Problems
By Outcast212 in forum Newbie / General discussionsReplies: 6Last Post: 21st Feb 2009, 02:11 -
No audio and subtitles in DVD-lab PRO2
By 6ZIX in forum Authoring (DVD)Replies: 13Last Post: 11th Feb 2009, 08:14 -
Switchable audio streams in DVD Lab Pro
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 9th Mar 2008, 10:54 -
dvd lab pro audio error
By tomoftenville in forum Authoring (DVD)Replies: 7Last Post: 6th Dec 2007, 16:05
