The deck is a JVC HR-DVS2EK (Mini DV/S-VHS). I’m wondering if I can’t capture live TV doing a ‘DV pass thru’ via firewire to PC?
Can’t see anything in the JVC’s manual.
I'm not familiar with that model. On my dual deck, there is a trick around it. Connect input to front RCA connectors, select the VHS deck. Use channel buttons and select L2. Press the Dub button to point to miniDV. Voila....the firewire should output....
Good luck
Avid not seeing Mini-DV deck
By hlaycanson in forum Capturing and VCRReplies: 7Last Post: 8th Dec 2011, 21:24 -
Looking for mini dv deck
By CrippleCreek in forum MediaReplies: 0Last Post: 6th May 2011, 11:25 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 03:18 -
Need help capturing video via Firewire from JVC DR-DX5S to Mac Mini.
By Cyrax9 in forum MacReplies: 5Last Post: 6th Jan 2008, 18:21 -
Need info about capturing mini DV and which deck to use.
By Mr_Wizard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 6th Jun 2007, 11:05
