Hi all
I use WinAVI to create the Video_TS directory and then burn with Star Burn.
When I play it in my standalone DVD player (which is not new), I find that after about 20 minutes of playing, the DVD sticks and I cannot continue
Does not happen with VCD (if that helps at all)
If I play it in Windows Media Player, it seems fine
Lawrence
Read my blog here.
Teac is so obscure that http://www.nomorecoasters.com doesn't even have it listed. That doesn't give me a good feeling about it. You'll probably have to mail order Verbatim or Taiyo Yuden. I mail order almost all my media - that's just how life is when you care about quality.
I agree with guns1inger's post, but I do want to add that it is possible that your DVD player is becoming defective. It's possible that the DVD laser (it's different from the CD laser that plays VCDs, so that's why VCDs play OK) may be going bad or needs cleaning. Do a web search on how to clean a lens on a laser in a DVD player with rubbing alcohol. It rarely helps, but in some rare cases it does. So it could be any combination of the above - old player going bad, bad media, bad burning software. -
Think about it for a minute...
You've changed to good encoding software and good burning software. You've also changed to use good media.
I think jman98 has a point.
Your burner or player are going South.
Try one of your discs in someone elses player. If it works, look at your player.
Question on USB Memory Sticks..
By SE14man in forum Newbie / General discussionsReplies: 17Last Post: 15th Feb 2012, 10:57 -
.avi file "sticks" on dvd player
By Ogilvy in forum DVD & Blu-ray PlayersReplies: 6Last Post: 3rd Feb 2010, 13:24 -
Keep incense sticks and smoke away from your discs!
By bizzybody in forum Newbie / General discussionsReplies: 5Last Post: 19th May 2009, 21:12 -
Need cheap USB sticks
By SingSing in forum MediaReplies: 8Last Post: 2nd Nov 2008, 11:21 -
AVI sticks / stutters
By kr236rk in forum Authoring (DVD)Replies: 8Last Post: 20th Oct 2008, 18:41
