I've had my WinTV-Go for years now and its never caused a problem
Recently i formatted my pc and re-installed all the software.
I went to capture a VHS to my PC and some how the audios out of sync
ive always did things exactly the same yet its not out of sync? ive formatted my pc millions of times and neve rhad this issue
also for some reason when i play a vhs in wintv software there isnt any sound but there is when its finished recording
whats all this about never had this issue before? cant seem to get it to play sound
Im using a VHS with a SCART to S-VIDEO Cable and then the audio from the VCR is Photo >L 3.5mm Stero Jack
its around about 24ms out i think but i just cant seem to get it to sync
PLEASE HELP
	Same software and drivers for the card? If so, you might try newer ones. If not, maybe older ones. If nothing else has changed in hardware, then maybe it's a software/driver problem.
 I would also look to any other programs you have installed that might have similar capabilities. They may be conflicting with the cards drivers/programs.
 If you are using the exact same programs/drivers, there is also a slight possibility the the order in which the programs were installed may be causing a problem.
 Generally that card is very stable. Unless the card itself is having a problem, then it should be 'fixable'.
  VHS player connected to PC - all captured footage out of sync!By kingmustard123 in forum Video Streaming DownloadingReplies: 2Last Post: 30th Jul 2011, 16:23
  Problem with audio gradually going out of sync in ts file (captured video)By shadowofanubis6 in forum Newbie / General discussionsReplies: 0Last Post: 28th Feb 2010, 12:12
  Captured video/audio progressively out of sync (on linux)By daytooner in forum Video Streaming DownloadingReplies: 2Last Post: 26th Nov 2009, 00:26
  Captured VHS movie and .srt subtitle not sync'd. Any way to fix?By snafubaby in forum SubtitleReplies: 2Last Post: 17th Aug 2009, 02:52
  Audio sync problems when re-coding captured video. Any Solutions?By uart in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 18:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
