I would like to convert a letterboxed WS DVD to an anamorphic 16:9.
The DVD is NTSC.
I have read a few guieds/posts and know the general procedure:
Crop the top/bottom bars; Resize to 720x480; Encode to 16:9.
The (partial) AVS script given is usually this:
Crop(0,60,0,-60)
LanczosResize(720,480)
I assume this is for a movie with original AR 1.85:1.
The movie I want to convert has original AR 1.66:1.
I measued the thickness of the black bars in VirtualDubMod, and they are 44.
So I changed the script to:
Crop(0,44,0,-44)
But after encoding and authoring the DVD, the movie doesn't have the correct AR.
The people seem a little fatter than normal.
So I figured because of the peculiar AR 1.66:1, I have to add black borders on the SIDES,
in order to get final AR correct.
So I change to acript to:
Crop(0,44,0,-44)
AddBorders(20,0,20,0)
With this script the AR looks better but still not quite correct.
So my question is what is the correct width of side borders in AddBorders function?
Results 1 to 13 of 13
It's been a while since I've done a 1.66:1 video. But if memory serves, you crop off all the black from the top and bottom, then resize the video to 672x480, then add black bars on the sides to make it fill out the full 720x480 (that would be 24 on each side). I think that is how I did it, and it produces the correct AR.
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
OK, so the script should be:
Crop(0,44,0,-44)
LanczosResize(672,480)
AddBorders(24,0,24,0)
Is the ordering important here, i.e., first resize then add borders, vs. first add borders then resize?
Also every script I've seen uses LanczosResize function for resizing.
Is that the best to use? -
You've got it right - resize then add borders. That will make the final video the correct size.
I usually use Lanczos resizing, but I know a lot of people use Bicubic resizing. The Bicubic resizing makes things look a little sharper, I think. But I prefer to use the Lanczos resizing then add my own sharpening, if needed."Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
OK. Thanks for the help.
Just one more thing: I am curious as how you came by the border size of 24.
The resizing width I can understand, 720 - 2 * 24 = 672.
But I can't figure out the 24 border size.
Is there a formula? -
The border size would be the amount that is needed to make the resized video fill out the 720 width: 720-672=48. Devide the 48 by 2 and you get 24 for each side.
Zefram Cochrane
2073 -
question? how do I take a dvd I bought that is letter box and make it full screen(cover the whole screen) any simple way to do this? keep in mind I am new to all this thanks
Have you considered Spline64Resize? I've fooled with the Spline16Resize and was very pleased.
Darryl -
I have no idea what spline64resize is. is it a program that resizes? where do I get it as I said I am new to all this resizseing bit thanks for the help and advice
wanting to get rid of letter box video and make it full video. is there any self help places i could learn how to resize the video of a dvd? POINT THE WAY
An easy way is to use DVD Rebuilder. After you install it, open the ripped DVD with DVD Rebuilder, go to the Options menu, AVS Options, Advanced Options, then select Convert from LB 4:3 to 16:9.
I have not used this method so I can't say how good the quality is, but I have used DVD Rebuilder before, and it produces great results."Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
I have used this option many times. Excellent results.Originally Posted by j1d10t
Letterbox 4:3 to Anamorphic 16:9
By sjdean in forum Video ConversionReplies: 4Last Post: 29th Nov 2009, 16:09 -
From Letterbox to Anamorphic. Does it make any sense?
By Instant Martian in forum DVD RippingReplies: 4Last Post: 9th Aug 2009, 12:40 -
Converting Letterbox 4:3 to Anamorphic 16:9
By flaycrow in forum Newbie / General discussionsReplies: 4Last Post: 14th Apr 2009, 20:38 -
Converting 16:9 to 4:3 letterbox
By brianschmutz in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 03:15 -
Letterbox to Anamorphic with as little quality degradation as possible?
By beatchef in forum Authoring (DVD)Replies: 16Last Post: 5th Feb 2008, 01:10
