When I import a file in to a new movie it becomes a new title.
Are there any internal option if I want to add few more files to the same title (append) ? Or I have to merge all files externally and import in to a new movie.
Donadagohvi (Cherokee for "Until we meet again")
Choice 1 - Merge externally. Choice 2 - Use multiple titles. If you use multiple titles, you will need to link Movie 1 to Movie 2 etc. in the Navigation panel if you want the video to play through from one to the next.
You can insert a "Multi PGC Title" -- but that will limit you in terms of where you can place chapter points...
Regards,
George
dvd lab pro movie numbers regularise
By sumeshkri in forum Newbie / General discussionsReplies: 1Last Post: 24th Oct 2010, 02:28 -
How do I retain Chapter Points from Movie? [DVD Lab Pro 2]
By SupaDupaMonkey in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2009, 19:56 -
Question for those that use DVD-Lab Pro
By PharmBoy in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2008, 23:26 -
DVD Lab Pro - Movie clips in menu
By flipzoso in forum Authoring (DVD)Replies: 1Last Post: 26th Oct 2007, 03:38 -
End Movie Scrooling Titles in DVD-lab PRO
By fwerneck in forum Authoring (DVD)Replies: 2Last Post: 14th May 2007, 05:16
