    Jan 2008
    Australia
    Hi all
    When I download an AVI Video Clip and convert it to DVD so to play it on the stand alone DVD player
    The pictue is only less than half the screen and very uneasy to watch
    Is there any program that can give me a FULL screen?
    You help will be appreciated
  2. Member DB83's Avatar
    Jul 2007
    A little more information will help.
    What are the properties of the avi. Load it into mediainfo and post them here.
    What did you use to make the dvd ?
    Did you make it in widescreen ?
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    It would also be helpful to know the TV type. If you are playing back widescreen format video on a standard (4:3) TV, they your video will have black bars on the top and bottom. That is normal. Even most widescreen formats on a widescreen TV often have black bars on the top and bottom.
    Google is your Friend
  4. Member zoobie's Avatar
    Feb 2005
    Florida
    less than half the screen?
    it sounds like it was widescreen that was converted to widescreen yet again
