Hi,
I am considering purchasing Sony KDL-40D3500, which has full HD (i.e. 1920x1080) resolution but according to the manual (http://pdf.crse.com/manuals/3280663111.pdf , page 40) it can take only up to 1360x768 THROUGH IT'S PC (VGA) input. I checked other Sony full HD TV's, all except the X-series go (nominally) only up to 1360x768 on VGA.
I have a computer that can easily produce 1920x1080 from it's VGA (checked with my 21" CRT monitor), but has no DVI output. I was therefore hoping I could use the computer with the Sony TV at FULL 1920x1080 RESOLUTION but from the manual it seems I will have no such luck. Adding a DVI card into the PC is very difficult btw.
Does anyone here have any experience with sending 1920x1080 signal into the Sony KDL-40D3500 (or other similar model) VGA input? Is anyone willing to test it or is it known it does not work?
Thanks in advance.
Google search about this model: "PC/VGA only full hd if you connected by hdmi"
If the manual says it explicitly, I would assume the limitation to be true and expect to either put up with a lower resolution or, ideally, change the equipment. -
This would only make a practical difference if you were using the TV as a computer monitor for fine print or graphics detail and you were sitting very close. For a 40" screen at normal viewing distances, video will look fine upscaled from 1366x768.
http://www.kiva.org/about -
Originally Posted by shunThanks for your thoughts. I think it's annoying that a EUR 1400 piece of equipment cannot do what my 5-year old professional CRT can. I am wondering the Sony TV's are intentionally crippled on the VGA input... Anyway, since I don't plan to purchase any other source of full HD signal in the nearest future I think I will start looking at TV's with 1366x768 res instead.Originally Posted by edDV
No copyright control over the Vga input *cough cough* ??
The electronic components of the power part adopted a lot of Rubycons.
List of "really true native" 24P 1920x1080 AVCHD camcorders
By DVDRW in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 49Last Post: 4th Feb 2010, 00:55 -
"display aspect ratio" changes by itself after remuxing .mkv vide
By roise_r in forum Video ConversionReplies: 5Last Post: 2nd Sep 2009, 02:35 -
Seeking "One-Type-Fits-All" format to display on iPod, PSP and Bl
By GrayStrickland in forum Portable VideoReplies: 0Last Post: 25th Mar 2008, 10:12 -
Fairuse Wizard full version and adware "win32.rabio"
By ricardouk in forum DVD RippingReplies: 2Last Post: 13th Mar 2008, 11:56 -
Sony HT-DDW990 receiver - why display says "dolby digital 3/2.1"
By buzzinhornets in forum Off topicReplies: 6Last Post: 8th Aug 2007, 19:25
