Hi all, Hope someone out there can help, I'm sure someone has asked this question before, but I did a quick search and couldn't find the answer.
I just want to rorate a avi file I've captured off a camcorder.
But I don't want to buy any expensive software to do it. Is there any freeware software that will do it. I've been using VirtualDub, but can't find any option in it to do it.
Any help would be most appreciated.
Cheer
CC
	Use the rotate or flip filter (Video -> Filters -> Add filter)
 /Mats
	AviSynth plugin for getting any angle:
 http://avisynth.org.ru/rotate/rotate.html
	There are two rotate filters in VirtaulDUb. Rotate is limited to +/-90 and 180 degrees. Rotate2 allows any angle.
	Thanks guys. Didn't realise I had to do it through the filters option.
 That sorts it all out for me. Many thanks all.
 Cheers
 CC
  Freeware to edit/rotate MPEG2?By Vinnie Terranova in forum EditingReplies: 3Last Post: 5th Jan 2010, 06:13
  Best Freeware Software to use to Burn .avi to DVD(s)By csugal999 in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2009, 22:43
  How to rotate a MOV file? I just gave up.By Pixelrage in forum EditingReplies: 10Last Post: 28th Oct 2009, 23:30
  Rotate .MOV fileBy Leo48 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Apr 2008, 00:34
  looking for software that will rotate video 90 degreesBy jimdagys in forum Newbie / General discussionsReplies: 32Last Post: 27th Mar 2008, 11:47
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
