Hi friends...I have one video file and I have audio on 2 languages...How to make DVD so the person who put that DVD in the DVD player can choose his audio language to listen DVD between those two.
I never trued this because I don't know where to start... For regular DVD (one video and one audio file) I was always using DVD Movie Factory 4 or Sony DVD Architect. So any kind of help such is procedure and software needed is very helpful.
Thanks a lot
You can do it in DVD architect. Simplest method is to demux both audio streams and convert to AC3 either with Vegas or a separate application. Encode the video to mpeg-2, again with Vegas. You should now have three streams (1 x video, 2 x audio).
Create a new project add your assets and create a DVD.
I have not used DVDA to make multi-audio discs, so I am not sure how easy it is to make buttons to switch audio tracks. If you have no menu then you can just use the Audio button on the remote to switch between them.Read my blog here.
A ha..for editing I am using MAtrox RT2500 which capture separated video and audio...so when I export movie as separated video and audio..I am using eather TMPGEnc or Main Concept encoder to encode to MPEG2..
That part is Ok..but how to make it to switch between audio in DVD...that's what I don't know to do...I will try as you said and write back..thanks -
In DVDA (Full version, not the "Studio" version), make the ACTION for the menu button set the audio track. You can also set up scripts in versions >= 4.x, but that's a little more complicated...
Regards,
George -
Ok..thanks...I made it with 2 audio tracks in DVA..
Thanks a lot to everyone
Arvin
Blu Ray to MKV with optioinal multi-language audio/subtitle support
By minerva.thegift in forum User guidesReplies: 10Last Post: 6th Oct 2014, 03:53 -
Multi-Language Subs
By DeathStalker77 in forum SubtitleReplies: 34Last Post: 29th Nov 2010, 00:13 -
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 17:34 -
Guide Needed for Authoring Multi Language DVD with multi language menus
By kemimich in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 16:46 -
Can't get other languages out of multi language idx/sub
By diskdocx in forum SubtitleReplies: 0Last Post: 7th May 2007, 20:55
