Hi all:
I managed to convert sucessfully a dvd movie into avi file using alltoavi.
The problem now is that I have severall avi files that I cannot join using virtualdub.
It seems that audio rates are not the same !!!Is there any way to make alltoavi convert into one single avi file ??
Or what might have caused the different audio bitrates ??
Results 1 to 9 of 9
All it requires is a ripping tool, which you need anyway, and Xvid.unfortunately autogk requires too much external codecs and another ripping program to do the job.
My (admittedly brief) testing found no way to set splitting or not, and I couldn't get it to produce more than one file, regardless of the bitrate used. Even with a high bitrate and an output larger than a single CD in size, I only got a single file. I also couldn't get it to correctly resize the frame - all the output was badly cropped. Full mkv support my arse.Anyone knows how to convert to a single avi file using alltoavi ??
edit : OK. I can get it to produce correctly scaled output if I use normal mode first, let it fail, then use restricted mode. Quirky little bugger. But so far, only one file.Read my blog here.
Converted a couple of MKV files over night to test, and all of them produced one file each for output, regardless of size. Could find no setting to cause or restrict the number of chunks created as output. I am at a loss to explain how you are getting multiple files.
Read my blog here.
Alltoavi
By jarko in forum Video ConversionReplies: 4Last Post: 28th Nov 2009, 08:43 -
Can you set alltoavi to produce a single AVI from multiple VOBs?
By benvid in forum Newbie / General discussionsReplies: 0Last Post: 18th Oct 2008, 12:25 -
Trouble converting OGM to AVI in AllToAVI
By m93 in forum Video ConversionReplies: 8Last Post: 21st Jul 2008, 19:21 -
AllToAvi
By natty in forum Newbie / General discussionsReplies: 3Last Post: 10th Jun 2008, 15:49 -
vob to avi using alltoavi (problem)
By anlaoch in forum Video ConversionReplies: 5Last Post: 22nd May 2008, 18:54
