I use dvdlab pro to compile my dvds. .I have to have multiple movies in one dvd....suppose i have five movies namely TIT-1,TIT-2,TIT-3 AND SPEED-1,SPEED-2 .....I take the files one by one. ..adds to the project..... then i want to make a menu.... I take a background and a frame then buttons. then i format the buttons with necesary color when highlighted. then i add text to each button. the text is nothing but the names of the movies. then I link the button with each movie. I link movie one(TIT-1). i get button number 1... Then i link movie number two(TIT-2). I get button number 2. then i link movie number three(TIT-3) I get btn number 3...Then i link movie number four(SPEED-1). ...suddenly --- I get butn number three for movie number four (SPEED-1)and the butn number of movie number three(TIT-3) changes to four. Why this happen. I add each movie in the right order. Even though I get the button number mismatched why ...plz suggest.
Results 1 to 12 of 12
One reason someone might want the button numbers to be "sequential" is if they are also relying on the Remote Button Numbers to correspond to the menu choices (so a viewer can press a number to jump to the menu choice).
Regards,
George -
They number as you connect, however you can change numbering after.
Open Menu and click on Lyrs on side, all buttons will show in window.
There are two yellow squares on top of menu window with gray circle on right bottom side. Use those to move buttons order as you desire. -
-thanks for all comments. that is one reason Mr.George.
another reason is when i get the butn numbers in unsequential order the menu item button highlighted property is not available for all buttons. Though i have given the effect to all buttons in the same manner. one or two may show the highlighted color others will not. if the butn order is correct then the highlighted feature when i move the arrow in the remote will be available for all btns. -
i just wanted to know how the button number change all of a suden when ai make a link. until then it was ok but ...as i have noted in my post.it is not htat i want a particular button number . it should come in sequence as i link one movie to the second.
I don't understand what you are doing then.
If I create 5 buttons, and link them in order to 5 movies, the buttons will be numbered in order (1 - 5). If, however, I link button 1 to movie 1, then button 2 to movie 2, then button 4 to movie 4, then button 3 to movie 3, and finally button 5 to movie 5, I will get a numbered order 12435 as the buttons are numbered in the order they are linked, not the order they are created, or the order they are placed on the screen.Read my blog here.
plz refer to gunslinger post on jan11. line one
it is not happening in my case. i create one button. give attributes. then copy paste five times if i have six movies or four times if i have five movies. then i give text to it. then (right click on the button and link) i link first movie to button i. i get butn 1. then i link movie two to the next butn. i get btn 2. then i link movie three to the next button. all of a sudden the second button number changes to three and the latest linked butn gets btn number two. this is what happens. to make a correction ,...i remove the link and then i mannually drag and drop the movie to make the link .even then i get the same mismatched btn number. -
I would suggest you report the issue at the DLP forum at Mediachance : http://www.mmbforums.com/ipb/index.php
The author is a frequent visitor there, so you may well get a fix.Read my blog here.
I do not know what version of Lab you have , but there is an update which fixes some problems created in last updates.
I do not know if this will help, but try it.
http://www.mmbforums.com/ipb/index.php?showtopic=19364
You do not have to remove links to change button numbers, just open menu and do what I sugested in post from Jan9/08. Post#1797639
Music in your DVD Menu's with DvdLab Pro
By RickyPinxt in forum Authoring (DVD)Replies: 5Last Post: 8th Apr 2010, 18:45 -
One subpicture overlay across menu cells? - DVDLab Pro
By nostrum in forum Authoring (DVD)Replies: 0Last Post: 8th Feb 2010, 11:36 -
DVDLab Pro Menu Text Disappearing
By C0SM0 in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2009, 17:33 -
DVDLab Pro Menu Structure Questions
By raouliii in forum Authoring (DVD)Replies: 1Last Post: 4th Dec 2007, 22:32 -
DVDLab PRO - Music in Menu
By poutniksantiago in forum Authoring (DVD)Replies: 8Last Post: 15th Nov 2007, 08:28
