I burned few xvid files onto a tdk dvd-r (using windows vista and ashampoo burning studio) i burned it as data dvd files..when i inserted it into my philips divx divd player (model: dvp 642/37) i get a "no disc" sign over and over again..
what is the problem?
please any help would be appreciated
Results 1 to 9 of 9
i just verified and i see all the files via my computer...
if i use build mode, wont the dvd player still say "no disc"..is this a dvd player issue? -
i have used tdk dvd+r and they worked fine on the philips but these are tdk dvd-r..i thought the dvd-r should work
It's probably a media issue. TDK may be outsourcing their DVD-R discs and maybe the new ones aren't very good. I have the DVP-642 and it generally plays any DVD-R I throw at it, but it's been years since I've bought any burnable DVD other than ones made by Verbatim or Taiyo Yuden. According to http://www.nomorecoasters.com TDK DVD-R discs were very high quality, but again, it's possible that they've changed who makes them and maybe the ones you have aren't very good. Verbatim has outsourced all of their DVD+R DL discs to India and while they mostly appear to be OK, I would say that overall they are somewhat inferior to the ones that used to be made in Singapore. You'd not get a coaster in a 25 pack of the ones made in Singapore, but you might get 1 coaster now from the Made in India media. For best results, I personally recommend that people use either Verbatim or Taiyo Yuden single layer DVD discs.
Note also Ai Haibara's excellent post. Multisession is a horrible idea and this will definitely be a problem if you did that. Anytime you burn anything you want to play on a DVD player, you MUST without exception burn it in a single session, finalize the disc, and if your burner gives you a choice between "Disc at once" or "Track at once" use "Disc at once" mode.
I know nothing about Ashampoo but around here we recommend using the free ImgBurn program because it works correctly all of the time and many other burning programs do not. -
thanks so much for all the replies!
well i know the tdk dvd-r and dvd+r work for sure because when I burn dvdr files on them they work fine on the phillips...
it might be the multisession issue..i was unaware that img burn could burn data files onto dvd..do I just add the xvid files in build mode of imgburn, any other settings i must change?
Womble mpeg video editor I get "No disc or disc error"
By pumpkinslion in forum Newbie / General discussionsReplies: 2Last Post: 3rd Nov 2010, 19:32 -
"wrong disc inserted please insert the cd/dvd"
By SIRCOOKS in forum ComputerReplies: 5Last Post: 14th May 2008, 11:49 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 08:08 -
RETAIL DVD plays in standalone - "No Disc Inserted" message in PC
By prattitude in forum Software PlayingReplies: 6Last Post: 28th Nov 2007, 12:07
