I bought a WinTV HVR 950 capture card and captured some over-the-air programs, and I wanted to edit out some commercial breaks. However, I was not able to import the captured file directly into Premere Pro 2.0 on my computer, each time I tried the import, the computer just freezes and eventually I had to quit the program. I tried different project settings but still no good. The capture card setting says the captured video is DVD 2048, doesn't know what that means. Anyway, just want to find a way to edit the video, any advice would be appreciated.
I've been experimenting with AviDemux(ignore the name - just try it) with my caps from my Hauppauge PVR-350...it hasn't rejected a file yet.
I suspect you are capturing at the highest quality on your card....I haven't used that setting yet on my Hauppauge and it may just be your only option on your WinTV card I'm afraid. I've seen some complaints about that. -
DVD2048 is a format that can't be read by Adobe. I understand that some people re-encode DVD2048 to standard MPEG2 (for DVD edit and authoring) using VideoReDo (about $30). In any case, DVD2048 is not compatible with the standard MPEG/DVD format. Users also say DVD2048 can't be played in Windows Media Player, but can be played with WinDVD.Originally Posted by cristolin
Are you talking about recording digital TV? If so, it's MPEG _TS, transport streams that is. What little I can find by searching the term "dvd2048" isn't very enlightening. Must be terminology peculiar to Hauppage?
Try this for transport streams, it has basic editing capability and commercial detection, output is standard MPEG2. One of the best little programs I've come across in awhile. Free, here:
https://www.videohelp.com/tools/HDTVtoMPEG2
Good luck.
Pull! Bang! Darn!
How to split and edit captured video
By perinet in forum Video Streaming DownloadingReplies: 0Last Post: 22nd Nov 2009, 10:40 -
Captured Videos Issue
By Equarter in forum Video ConversionReplies: 18Last Post: 19th May 2009, 19:43 -
Captured now edit..advice
By aussiemac in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 17th Nov 2008, 12:52 -
Captured all my old home videos to AVI... now what?
By w@ntonsoup in forum Video ConversionReplies: 11Last Post: 26th Feb 2008, 19:05 -
How to edit captured stream ?
By DuBsTaR in forum Newbie / General discussionsReplies: 3Last Post: 20th Feb 2008, 12:52
