Results 1 to 17 of 17
    Apr 2005
    Houston, Tx.
    Is anyone else having trouble using DVDFab HD Decrypter for these two movies? It will not even recognize Shoot Em Up and 310 To Yuma locks up while being ripped to the hard drive. This is the only program I have ever used and have never had any trouble.
    Thanks,
    Rob
    Oct 2007
    Downloading the latest DVDFab HD Decrypter 4.0.3.2 will recongnize Shoot Em Up, but I'm also having lock up problems with 310 To Yuma.
  3. Member GMaq's Avatar
    Mar 2004
    Canada
    Hi,
    Just backed up Shoot Em Up with latest AnyDVD and DVD Decrypter with no issues. It's just a matter of time until either DVD HD Decrypter or AnyDVD catch up with 310 to Yuma.
    Oct 2007
    I just tried CloneDVD2 on 310 To Yuma, which appears to be working.
  5. AnyDVD already handles 3:10 to Yuma as it should without any need for an update.
    Oct 2007
    To confirm CloneDVD2 backed up 310 To Yuma without a problem. AnyDVD did not work.
  7. You can use the latest DVDFab HD Decrypter (Version 4.0.4.0 Beta) to rip the Full Disc of 3:10 To Yuma. Run the Full DVD of the files you ripped through FixVTS. You can put the newly fixed DVD into DVD Shrink and backup the DVD any way that you'd like (movie only, full disc, whatever). Hope this helps.
    Knowledge is Power, For Real!
  8. Member Baatfam's Avatar
    Mar 2005
    Carol Stream, IL
    Surprisingly...after DVDFab HD Decrytper failed, I tried the last version of RipIt4Me and it worked!
    It had one error during the process, which I told it to ignore and I ended up with a fully functional disc.
    Go figure!
    This was last Friday and I didn't have the newest Beta of DVDFab.
    Bob T.
  9. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Another typcial Tuesday post.
    Google is your Friend
    Feb 2006
    Emsworth, Hampshire, UK
    3.10 to Yuma - AnyDVD and TSRemux produced a sweet ts file that plays perfectly
  11. I can't get 3:10 to Yuma to shrink using DVD Shrink. I am trying to backup the movie and nothing else and it's still too big. I have never experienced this before, anyone have any suggestions?
  12. Nevermind.
  13. I was actually able to do 310 to Yuma using RipIt4Me then DVD Decrypter after the latest version of DVD HD Decrypter gagged on it. Burned to DL DVD with no problems. This was the day the movie came out, actually.
  14. Member Seeker47's Avatar
    Jul 2005
    Go figure!
    The demise of RI4M's usefulness is much exaggerated, I'd say. I continue to get good results with it, even on some titles that are recent enough that one might not expect it to work. It's good to have a lot of tools in your toolbox -- you never know when one or another of them might come in handy. I wouldn't completely or categorically write off SmartRipper, either.
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
  15. Member archaeo's Avatar
    Mar 2004
    mountains
    I used Ripit4Me on this title, using wizard mode, and creating a psl file to rip from. It worked fine.
  16. Originally Posted by Krispy Kritter
    true true
  17. Originally Posted by Fathead31
    Why nevermind? This is exactly the problem I am having.
