I changed my original post since I found the answer. I just analyzed to copies of files that I have where the video is basically the same but the file size is around 100 mb different. The larger file is encoded using XVID while the other file is encoded using DIVX 5.1. What's the best codec when considering size of the file? I'm looking for something in between. In this case, I prefer the 100mb smaller file as the quality is the same as hte other file.
Also it appears that x264 codec is giving me the best possible quality. Is there a drawback to using AVC over DIVX?
AVC is not supported on most standalone players, DIVX/XVID have much more support
AVC takes up more CPU resources to encode and decode -
Overall is just better to stick with DIVX or XVID? which version is better for encoding?
I think you've answered your own question!Originally Posted by DonGallego28
But you'll find that the difference in size ISN'T due to the encoders (DivX and XviD are pretty close to each other in that regard) ... they were just produced using different bitrate settings. Personally, I use the ASPECT utility for determining bitrates; enter the play time, aspect ratio (4:3, 16:9 or custom) & audio bitrate you commonly use - now enter the file size required & it'll give the video bitrate to use. Also, hit the AUTOSIZE button & it'll give you the framesize to use at that bitrate to keep "reasonable" visual quality. A small 350 MB encode probably won't produce HD screen resolutions!
Trev
Output size in AVStoDVD
By VenusAndMars in forum Authoring (DVD)Replies: 2Last Post: 25th Nov 2010, 17:07 -
Converting Divx-AVI to MP4 - Output size option doesn't work
By tomzero in forum ffmpegX general discussionReplies: 6Last Post: 20th Mar 2010, 07:30 -
WinAVI output file size
By Akusai in forum Video ConversionReplies: 21Last Post: 5th Oct 2009, 06:54 -
different output file size in convertx2dvd
By Iwan2learn in forum Authoring (DVD)Replies: 13Last Post: 13th May 2009, 02:29 -
Problem with DVD output size
By senecalax25 in forum Authoring (DVD)Replies: 2Last Post: 21st Sep 2008, 03:08
