I created a .bat file with the lines below:
"C:\Program Files (x86)\VSO\ConvertXtoDVD\ConvertXtoDvd.exe" C:\Users\Name\Documents\ConvertXtoDVD\Projectfile0 2.xToDVD /auto=true /close
When I run the file, ConvertXtoDVD opens and then a window opens asking me to select the project to ocnvert. The directory that opens is C:\Users\Name\Documents. The program won't open the convertxtodvd folder where the project is located. Any help would be appreciated.
Ty!
Try it all on the 1 line.
"C:\Program Files (x86)\VSO\ConvertXtoDVD\ConvertXtoDvd.exe" "C:\Users\Name\Documents\ConvertXtoDVD\Projectfile 02.xToDVD" /auto=true /close
Boy! I hope you're eyesight is better than mine.
oops. Was the string on 1 line?
I copied it from another thread on here and it was all on one line, but I think my notwpad window wrapped it on it's own. I'll try that out.. might be just that simple.
Thanks! -
I figured it out. I had to put " around the path to the project file.
Thanks!
ConvertXToDVD Subtitle encoded file?
By theamilien in forum SubtitleReplies: 0Last Post: 16th Aug 2010, 04:07 -
Can I batch convert with convertXtoDVD?
By coopgang in forum Video ConversionReplies: 10Last Post: 23rd Jun 2010, 06:15 -
Once a video file is loaded to ConvertXtoDVD - we see a different file size
By mahogany in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2009, 19:52 -
Batch Convertxtodvd
By jack1993 in forum Authoring (DVD)Replies: 6Last Post: 18th Oct 2009, 22:28 -
ConvertXtoDVD not recognizing Sub file
By Swanee in forum SubtitleReplies: 2Last Post: 7th May 2007, 21:04
