Hey guys!
I have 3 mpg files that i am trying to convert to dvd, my usual method would be to load the file into convertxtodvd and author the final output using TMPGEnc DVD Author, But for some reason when loading the 3 files in convertx it tells me that all 3 clip are only 5mins long when in fact the 1st 2 are over 1hr and the final is over 30mins. If i begin the convertion then it will convert the 1st clip but only part of it.
I tried converting the files using TMPGEnc Xpress but get a similar problem, any ideas whats could be causing this and how i can fix it?
	And can you play them fully with WMP ?
 if so, you could import a AVISynth script in VSO ConvertXtoDVD using DirectShowSource
	I would first check them with Gspot 2.70 and make sure they are DVD compliant. See 'WHAT IS' DVD to the upper left for the specifications.
 If they are compliant, the files may be corrupted, maybe from a bad join or cut. Your software players may not notice it. You could try to put one in a video editor and find the area where it quits and examine the frames. I've used VirtualDub Mod for that. It may also tell you about timeline problems or bad joins.
  MPG won't play properly in VideoRedoBy terrypin in forum Newbie / General discussionsReplies: 3Last Post: 31st Jul 2010, 18:13
  MPG to MPEG4 worked great, now it won't...By andersonfamilyfarm in forum Video ConversionReplies: 3Last Post: 10th Jun 2010, 17:01
  .mpg won't open/burn correctly-help!By keltoid in forum Video ConversionReplies: 6Last Post: 14th Dec 2009, 12:11
  mpg files won't play in IEBy Krispy Kritter in forum Software PlayingReplies: 3Last Post: 31st Oct 2008, 14:42
  VOB2MPG won't create the mpgBy Heibi in forum Newbie / General discussionsReplies: 6Last Post: 6th Sep 2008, 18:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
