I had a flash drive transfer going that went over the drive's capacity (a Verbatim drive). It came up with a message to insert another disk (like a stone age floppy would've done). I cancelled out because the files I actually needed to tranfer were already on the flashdrive.
I was surprised at the other machine, when doing the transfer that it asked that I insert the second disk to continue... apparently there is a file splitter capability somewhere in the flash management system.
I couldn't find it on the flash drive so I'm thinking its something windows does... ?
this could be handy for moving humungeous video files-if it always works.
Very surprising indeed. I'd expect XP to treat this as a HDD and just give a "not enough space" error.
Google is your Friend -
I don't think it would split your files. It would just not write the file that went over the limit. Then if you inserted a new drive, it would try to put that file and the rest on it. This would all be a PITA if the file was only a few KBs over the amount of room left on the first drive.
And I think that's all a feature of the OS. (And I have never tried it with a flash drive, so I don't know that it would work.
It's nothing special. The operating system sees it as a removable disk, like a stone age floppy. With the exception of wanting you to stop the drive before you unplug it, it pretty much treats them the same. As far as splitting, you might run into a problem as unplugging that flash drive and plugging in another one (especially a different brand or even model) will more than likely result in a different drive letter. The old drive letter will go away upon unplugging and most likely kill the file transfer.
Nothing can stop me now, 'cause I don't care anymore.
Flash Drive
By tcory in forum Newbie / General discussionsReplies: 5Last Post: 12th Dec 2010, 20:25 -
flash drive
By Pumkinhead in forum ComputerReplies: 5Last Post: 19th Nov 2010, 03:05 -
Anyone used a 64gb flash drive?
By js2k in forum Newbie / General discussionsReplies: 10Last Post: 3rd Dec 2009, 20:38 -
Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
By vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 18:38 -
Problem with a Flash Drive
By The Monkees in forum ComputerReplies: 5Last Post: 19th Nov 2007, 17:42
