I recently borrowed a friend's high definition Sony camcorder HDR-HC3 to film a family event. Using a firewire cable, I then was able to capture the 60 minute tape to my hard drive (using something was on the HP computer when I bought - a program named Muvee Producer or something like that).
I now have a 13+GB avi file sitting on my hard drive that plays fine using an old freeware version of BSPlayer.
But, I'd like to convert that 60 minute, 13GB AVI file, to something that I can burn to a DVD-R for friends and relatives. I still have the tape from the camcorder, but I had to return the Sony unit so I have no (easy) way to re-capture the file on the tape (so hopefully I did that part right).
I'm not concerned about adding chapters or other things that will make the DVD fancier, etc. I just want the 60 minutes on a DVD. I'm told I may be downsizing (or downgrading?) the HD to DVD, but that doesn't concern me (I don't even own a high def tv - nor do any of the relatives to whom I'll be sending the DVD-Rs, if I can get those to work).
Any suggestions of programs to use (preferably freeware)? My computer came with the Sonic DVD modules so if I can use that, that would also be great.
TIA.
first find out if you really have an HD file. if it's an avi it might be SD, normal cam miniDV. the cam you borrowed can record/transfer either HD or SD. try gspot and see what it says the file is.
then go the links on the left and look through the guides for converting to dvd mpeg.--
1920x1080 / 59.94i Footage From High-Def Camcorder - TMPGENC Auth. Works 4
By bmccollum in forum Authoring (Blu-ray)Replies: 8Last Post: 19th Oct 2010, 13:31 -
Footage from Samsung HMX-H205 High-Def Camcorder to AVCHD - Sync Problem
By bmccollum in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 18th Oct 2010, 14:25 -
High def camcorder, what video format you get ?
By geek2330 in forum Newbie / General discussionsReplies: 4Last Post: 14th Oct 2008, 03:03 -
How may I record in High Def and Playback in High Def ?
By MacPCConsultants in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 7th Jun 2008, 17:28 -
Problem converting high def .mkv files
By KPKMP33 in forum Video ConversionReplies: 1Last Post: 9th Nov 2007, 08:12
