    Oct 2007
    I'm using AVS Video Converter V5.6.
    When i try to convert a .avi file to DVD format, for burning to DVD disk, i get no Audio files.
    The program creates the filder, "Audio_TS", but ther are no files in it.
    Anyone have any ideas?
    Thanks in advance,
    Corey
    Oct 2005
    666th portal
    the audio_ts folder isn't used. it's supposed to be empty, all the dvd files go in the video_ts folder.
    Oct 2007
    Thank you so much, but this brings about another question! lol...
    In the past, when i have downloaded files in DVD format, some of them have had files in the audio filder.
    why is this?
    im starving for information. please ignore me if im bothersom. hehe
    thanks though.
  4. Sounds like screwed up DVDs you downloaded. Audio_ts is for DVD-audio discs.
    Darryl
    Oct 2007
    haha. thanks...
    i love forums!
    Oct 2005
    666th portal
    click the link in the upper left that leads to "what is" dvd. if you get near the bottom there is an explanation of what's supposed to be in the folders.
