Sharp has several 32" 1080p LCD models ranging from about US$950 to US$1250 at Amazon.com. I don't know how good they are though. Their 720p models are a few hundred cheaper. All else being equal, at that size you would have to sit less than ~5 feet away to see a difference.
Results 31 to 33 of 33
Brand names each have their own version of image processing chips usually offered in two or three quality levels. For example Sony has a value line and two XBR levels for their LCD-TV sets.Originally Posted by snadge
As a general statement, Sony, Samsung and Sharp are usually considered better for processing in their high end LCD-TV models where Pioneer and Panasonic are often mentioned for plasma.
Bargain models use generic chipsets. In general you are better off with the latest generation chip designs. Try to figure out when the specific model was introduced. Other clues are inclusion of digital tuners and more HDMI inputs which are recent trends for low end models.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
to snadge, upscaling DVD players are NOT a need. They are there tp present an alternative to an ordinary DVD player such that you can try and see if the DVD's upscaler will produce a better picture than the case would be if you just fed an ordinary SD signal to the LCD monitor and LET the LCD do the upscaling. You now have a choice of two scalers there, so to say. With so many signals out there it's hard to predict what will faze any scaler in either the DVD player or the monitor so it's always best to have a choice. For example, in my situation, on a majority of 480i SD DVDs I play on my DVD-S52 Panasonic player connected to the PT-AE900U projector either by HDMI (DVD player output set to 720p to match the native 720 of the projector) or analogue progressive component (of course the projector alone will scale the 480 to 720), the HDMI connection looks marginally better.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
Convert HDTV 1080i to DVD5
By marvell in forum DVB / IPTVReplies: 6Last Post: 24th Mar 2010, 07:19 -
Can an hdtv w/ 1366x768 resolution have a display compatibility of 1080i?
By Remedial in forum DVB / IPTVReplies: 6Last Post: 11th Aug 2008, 15:06 -
"Unsynched repair block" on 1080i .TS HDTV file
By Pliny in forum DVB / IPTVReplies: 1Last Post: 13th Jun 2008, 03:57 -
Resolutions...why call it 720p when the res. is 1366x768 ?
By snadge in forum DVB / IPTVReplies: 4Last Post: 29th Aug 2007, 18:30 -
HELP WITH RECIEVING CLEAR 1080i RES
By sicl6lsic in forum DVB / IPTVReplies: 7Last Post: 11th Jul 2007, 09:24
