I would like buy IDE to USB adapter cable http://www.cross-mark.com/3in1-sata-cable-adapter-serial-p-772.html for my old IDE hard drives, but I haven't tried that before. Can anyone tells me it can hot plug the hard drive to usb cable? If yes , is there need a driver for this device?
Thanks![]()
You'll have to ensure the drive is set to Master, Slave or CS if IDE.
If it's set up right, these work fine - unless the power supply or cable is bad.
Yes, I've had one shipped that was bad.
They're not made extremely well, but get the job done.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
I used a similar one when cloning my laptop hard disk.Originally Posted by AusTaylor
It worked with Win2k and WinXP, appearing as a USB disk, so if you can use, eg, USB flash drives, it will work with the OS drivers. "Hot plugging" at the PC end seemed to work, again as well as any USB storage. But I would take care to connect the header to the drive before plugging in the power or USB connection to the PC
However, I had mixed results using Linux, some software would detect the drive, some didn't, and I never got any Linux cloning software to work with this. But the free XXClone for Windows worked more or less, with Fat32 more reliable than NTFS, though YMMV.
Sadly my PC only has USB 1.1, so backing up was very slow, if you have USB 2, it should be more pleasant.
For 2.5" drives the power comes from the USB cable, for 3.5" you need the separate power cord.
Really? I didn't play with my jumpers, it was set as Master, but I thought it would be irrelevant for USB connection.Originally Posted by classfour
(And which of "Master, Slave or CS" anyway?) -
There are no other options to set a drive to...Originally Posted by classfour
I wouldn't suggest that model. I'd go with the bytecc model. Because its power seems to be better implemented and I've ran to situations where you'd have to have correct sata and data corrections, separate connections would be difficult.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812156102
Keep your phone away from it though. Its more expensive but its dependable and works well in most situations. Its a standard USB Drive, so anything above windows 2000 will already have drivers for it. -
Actually, Win2k copes with USB drives quite well, except for the annoying "stop this device before removing" nagging that XP seems not to have so much.Originally Posted by bigstusexy
I'm sorry I meant to print windows 2000 and above.
Its a good idea to properly eject your drive because the OS doesn't flush its buffers until you do. I wish they would flush it after they are done and just leave the drive alone, in a perpetual state of being ready to remove. -
bytecc's do not need any driver other than what is already used for usb storage devices. if a usb memory stick works on your comp it will also. i have several of them and the always work without any problems.
SATA to IDE adapter.
By Poppa_Meth in forum ComputerReplies: 31Last Post: 6th Jan 2014, 15:47 -
Digitizing to Mac Book Pro using adapter cable
By rawdealmonty in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 5th Dec 2010, 13:16 -
S-Video to HDMI cable/adapter
By JohnnyBob in forum Newbie / General discussionsReplies: 16Last Post: 22nd Nov 2010, 12:42 -
Where to find a ZIF to IDE adapter
By VirtualDoobMon in forum ComputerReplies: 8Last Post: 14th Apr 2009, 08:27 -
IDE to Sata adapter....
By kenmo in forum ComputerReplies: 4Last Post: 2nd Apr 2008, 13:11
