  1. Hi while i am trying convert an MKV file to DVD but the mkv file has 2 audio languages English being second, since i cannot choose which one i want, FAVC picks the first one. so i use mkvextract to extract the first language and mkvmerge to merge the english and video. then i put it through FAVC still no success. this time there is no audio at all.
    can somebody help me.
    Jun 2005
    Portugal
    It should work, can you play that file in WMP ?
    what is the audio format ? AC3 ? AAC ? DTS ?
    if it is AC3 or DTS just convert the video with FAVC, you just need the elementary video stream...discard the rest
    then use MUXMAN or other authoring tool to mux your audio with the video and author the DVD
    if it is AAC then you must convert it using FAAD
  3. i did that. it says "could not open input file".
    Apr 2004
    Miskatonic U
    What does g-spot say about the FAVC output that appears to have no audio ?
    Read my blog here.
  5. yeh i dragged main vobs which favc outputted and no audio present
    Jun 2005
    Portugal
    if you didn't save FAVC temporaries : use VobEdit to demultiplex the vob files, or other tool like ProjectX
    then as I said before use MuxMan to author the DVD with the audio
    is just that simple
    Apr 2004
    Miskatonic U
    Which version of FAVC ? There have been a number of issues reported with 1.05. I am still using 1.04 and do have these problems.
    Read my blog here.
  8. Member Mr_Odwin's Avatar
    Feb 2006
    FAVC will not produce vobs with no audio track - it just won't.
