I have been trying to convert MKV files to AVI but i have encountered problems
I have tried AlltoAVI but every time I start it up I get and error message saying:
"Run-time error '372'
Failed to load control 'MMControl' from MC132.OCX. your version of MC132.OCX may be outdated. Make sure your are using the version of the control that was provided with your application."
I hav asked the creator of the app witch wasn't very helpful.
I have also tried VirtualDUB using this tutorial: https://forum.videohelp.com/topic341999.html
I don't know how to get the Lame MP3 to appear in the compression...
Help would be appreciated
Download the LAME MP3 ACM archive and unpack it to a folder. Locate the inf file (or if you have extensions hidden, the one that widows calls an Installer), right-click and select Install. Say Yes to any security dialogues that appear. You should now have access to LAME through Virtualdub.
Read my blog here.
thank you for the helpful info this did help!
but does anyone know what MC132.OCX is? sorry to pushy. -
You sure it's not MCI32.OCX? In that case, it's a Visual Basic Multimedia Control, which makes sense in this context.
/Mats -
Do you have a link to where i could find that then, cause I've had a look around but I'm a little confused about which one I need. ty
Neither do I know. Use Google to search for MCI32.OCX - I'm sure you'll find plenty.
/Mats
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 02:45 -
Problems with an avi to MKV conversion
By Paxmilitaris in forum Video ConversionReplies: 0Last Post: 21st Oct 2011, 14:11 -
converting mkv to avi + problems
By sgbd in forum Video ConversionReplies: 8Last Post: 28th Dec 2010, 13:53 -
MKV to AVI Problems
By Xandal in forum Video ConversionReplies: 7Last Post: 29th Aug 2007, 16:09
