I'm totallyconfused! I thought I had installed enough stuff to make this work, but guess not!
I'm on W2K so last WMP avail is 9 (AFAIK)...fine...and I just installed ffdshow based on comments from another forum related to file manager app that should preview it if WMP will play it...but that didn't help either.![]()
When I view either of the two files that I've got that have the FLV4/VP62 showing via GSpot, they don't show any handling of the video part in "proposed" unlike the FLV1 files...so guess that's part of issue? Also, it shows as "VP6F" in VLC but "VP62" in GSpot? Huh?
I can play these FLV4 files via Riva Player or the Applian Player (and VLC), but I'd like to get system set so that GSpot can do it as well as WMP.
This whole codec/filter thingy has me totally baffled at this point...as I see entries that seem to be needed (via GSpot displays), but something is still amiss...it shows that file goes thru FLVSplitter.av but then into audio only.
Hope someone can follow my wanderings and give me a pointer on what to do...thanks in advance!
Ok, so I went looking and found at http://www.moviecodec.com/downloads/16d.html a VP6 decoder, so dl'd it and installed...still no difference!
And in ffdshow video decoder config, I see VP6 (VP62) and VP6F (FLV4) listed as "libavcodec", so it appears that it knows of them...any other ideas?
BTW, my current WinAmp also plays it just fine...but GSpot and WMP don't..
Addendum/Upd: Media Player Classic also doesn't do it...I added External Filters for ffdshow and FLV as my guess but no effect. -
What's You version FLV Splitter?
Old version (original Gabest filter) can't handle VP6F.
You try latest clsid build?
http://sourceforge.net/projects/guliverkli2/
Maybe because Winamp have internal decoder (plugin) for VP6.Originally Posted by j_hallgren
You tray latest clsid build with active internal FLV splitter?Addendum/Upd: Media Player Classic also doesn't do it...I added External Filters for ffdshow and FLV as my guess but no effect. -
I hadn't known that my FLV Splitter was old!Originally Posted by Placio74
Thanks! After updating that, GSpot was able to handle it just fine!
I suspected as such, but it's good to know that fact...Originally Posted by Placio74
I was running what I thought was the latest vers (which I was, but the "original" path mod), but after your reply, I looked again and saw that a variant 'fork' was created that was more recent, which I'd not noticed before, so installed that and now it works also!Originally Posted by Placio74
BTW, the file also now plays just fine in WMP also! Success at last!
I was working on this for quite some time yesterday and was getting quite confused/frustrated so I REALLY do appreciate the help! Thanks again!
"Bit Error" when playing AVIs on set top box - video freezes
By MLS in forum Newbie / General discussionsReplies: 1Last Post: 15th Jun 2011, 15:26 -
gspot says "12.5 GB unneeded bytes at end of file"
By sasuweh in forum Video ConversionReplies: 6Last Post: 29th Sep 2010, 19:06 -
GSpot says "File missing" but it is clearly visible in Explorer window?
By Iceblade in forum Software PlayingReplies: 9Last Post: 30th Mar 2010, 09:41 -
video player that support "slow playing".
By bbchai in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2010, 02:23 -
Problems decoding FLV4/VP62
By drwho in forum Video ConversionReplies: 1Last Post: 1st Mar 2008, 19:16
