Results 1 to 13 of 13
    Jan 2003
    Brazil
    Do you guys know any software, like the "windows movie maker", except for avi files, that we can just say in what size we may want a / the new movie, and it adjusts all the others parameters for us?
    AutoGK if just need to convert to an avi divx/xvid, open mpg and set output file size and convert.
    Jan 2003
    Brazil
    Ok. I have another question. Do you have experience with the youtube? I mean, have you ever upploaded some things to there? I mean divx/xvid avis to there? If so, what about the result? There have been any sincronization problem? Video x Audio? I heard that this occurs, but I didn't try yet.
    Yep and it worked fine. I use avi xvid and mp3 cbr audio.
    Jan 2003
    Brazil
    ok, thanks a lot.
    Jan 2003
    Brazil
    Ok, but what if I would to convert to mpg4s? Do know any AutoGK ( kind ) for mpg4s?
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    What is mpg4s? or do you mean the mp4 container?
    Jan 2003
    Brazil
    mpg4 format!?!?
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    Yes, what is mpg4? Divx and xvid are mpeg4 formats and they can be stored in an avi file.
    Jan 2003
    Brazil
    I thought was a new format
  11. .mp4 is a container
    mpeg4 part 2 is a wide standard encompassing xvid, divx and others
    mpeg4 part 3 is audio AAC
    mpeg4 part 10 is AVC video compression
    mpeg4 part 14 is the mp4 container
    which do you mean? What do you want to convert (input) to what (output) container and codec? for TV? for xbox? for PC?
    Jan 2003
    Brazil
    It's because that I saw at the youtube site that we could get better youtube videos if we would upload mpg4 videos, or in mpg4 format, I don't remember.
  13. I'm a MEGA Super Moderator Baldrick's Avatar
    Read https://forum.videohelp.com/topic346256.html for youtube quality tips.
