Hi all sorry if this has bin asked befor but i am new here and i wouldnt know where to start lookin for the answer i want. ive converted 2 movies using xilisoft video converter but the audio is running 1-2 seconds infront of the video. Ive been using this software now for years and yes it has happened a few times but ive thought sod it and i put them in the bin but i dont want to do this as i want to kee these vids so i did a search on google a few night back and found some software to resolve this but ive lost it and i dont remember what it is call soooooooo does anyone know anything i can do or use to sort this prob out?
thanks to who and all that helps me out![]()
Results 1 to 10 of 10
Hello i thought i remembered having bin reading about a similar situation once before but i cant remember what xilisoft did perhaps did it create a file for you that is not playing the sound in the position you want. what type of file did xilisoft create for you is it on your computer hard drive or on a disc and what is the file extension and do you have the original file from which you started before xilisoft created the file or disc that is not to your liking?
that was my first post here. im converting files into psp mp4 and ive been doin this for some time its just these few videos ive had probs with
_kryten_, you will likely get better responses here with shorter sentences, capitalization at their start and periods at their end, and some paragraphs.
But, what format did you start out with? That type of sync problem can be a result from VBR audio formats being improperly re-encoded. Or sync problems can be caused by missing frames, corrupted video or audio, or bad cuts and joins.
If the problems don't exist in the original file, then something in the conversion process probably caused them.
And welcome to our forums.
ok well one of the videos is in an AVI format and the other is in a DAT format but both seem fine as thay are till i convert them as i said befor im no strainger to reformating/converting ive 144 movie plus many tv shows i have converted myself. i know there is software out there to use where you can aulter when the audio starts i found it once but i just cant find it now. Hay redwudz dont take afence to this but thanks for pointing out my dyslexia i do try my best
You can use VirtualDub or VD Mod to apply a offset to the audio in the amount of the sync error. That's if the error is the same amount the length of the video.
If the sync error changes, getting worse towards the end of the video, then the audio and video are likely different lengths. You would have to change one or the other to match.
Sync problems can be caused by bad joins or cuts, corrupted video or audio, or most commonly, bad conversions of MP3 VBR audio when converting the files to MPEG formats. Check the video in Gspot 2.70 and see if it has VBR audio. If so, extract the audio as a WAV or convert it to a CBR format. A guide for VD Mod: https://www.videohelp.com/forum/viewtopic.php?t=280779 -
There's a sticky at the top of this forum for sync problems: https://forum.videohelp.com/topic316884.html
Ideally, you'd still have your original source and are making the corrections the previous posters / stickies suggested.
It may be possibe to demux your mp4 with Yamb. Run the audio Yamb gave you with your 1000-2000 millisecond adjustment through an audio editor that accepts your acc or mp3 and rejoin the the two again with Yamb.
Remember your PSP is probably very particular about framerates bitrates frequencies and so on. -
Hay redwudz VirtualDub was the one i was looking for thanks alot bro that was a big help and sorry about the stuff before
How can I shrink down the running time of an audio file?
By darkzero297 in forum AudioReplies: 3Last Post: 16th May 2009, 13:07 -
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 20:59 -
DVD to H.264 - Different Running Times, Chapter Times Wrong
By nrogers64 in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2009, 19:28 -
Audio out of sync after running file thru virtual dub
By AORMan in forum Video ConversionReplies: 3Last Post: 2nd Oct 2007, 14:35 -
Should the audio and video times match in DvD Lab?
By janeydoll in forum Authoring (DVD)Replies: 14Last Post: 9th Jun 2007, 14:45
