Hi,
I am looking for some without compressing my movie again. I have a DVD MPEG2. There are 2 thing I like to do. The first thing is Muxing the audio before I cut. I tried VDMod and VD MPEG2 and I can't have it on Direct Stream Copy. That is the only way I know without compressing the movie. How do I mux audio into a DVD MPEG? How do I split a DVD known as cut?
First of all, I don't recommend abbreviating "VirtualDub" with "VD". It took me a while to figure out what you were talking about. Making up your own abbreviations is not a good way to get help.
Why do you want to mux the audio? You do understand that muxing means combining audio and video streams into one file right? Why are you doing this?
Both VideoReDo and MPEGVCR will allow you to cut videos. Both are easy to use and can be used in "Try before you buy" mode. Both can cut DVD video accurately with the audio muxed into it already. -
Yes I know what Muxing is and right now. I have a separate audio file that means I have video with no audio. How do I get the audio in with the video? I like doing movies with no audio.
Originally Posted by jman98 -
You'd better learn to be more clear about what you want:
How do I mux audio into a DVD MPEG?So, which is it? If you have DVD compliant MPEG-2 video and DVD compliant audio and you're trying to join them to make a DVD, then you author them. Muxman is probably the simplest free and very good quality authoring program.I have a separate audio file that means I have video with no audio.
But if you already have a "DVD MPEG", then why are you asking about adding audio? It's not DVD until after it's been authored and is in the common IFO, BUP, VOB format.
If you just want to make an MPG and not a full DVD, then try ImagoMPEG-Muxer.
I have no idea what that means. You like to listen to your movies silently? You like to add your own audio to video? If you want help, then clearly define what you want, and stop making us guess. You say you're in the US. I think they speak English there.I like doing movies with no audio
Problems Cutting MPEG video in VIRTUALDUB
By Rudyard in forum EditingReplies: 2Last Post: 30th Sep 2010, 21:25 -
cutting MPEG frame by frame
By headless chicken in forum EditingReplies: 3Last Post: 9th Nov 2009, 19:45 -
New experimental TS cutting software for MPEG-2 and H.264 Transport Streams
By Nukster in forum EditingReplies: 2Last Post: 14th May 2009, 09:16 -
Convert mpeg-2 to xvid while cutting commercials...
By swishbish33 in forum Video ConversionReplies: 5Last Post: 25th Oct 2007, 18:10 -
cutting with mpeg video wizard but making my movie longer :S
By chocolate_brownie in forum EditingReplies: 5Last Post: 18th Aug 2007, 21:45
