How do I set my render files?
Mine keep going right to my trash and I don't want them going there.
I looked all over and so far I have not found a way to direct them.
Any takers?
FCP Preferences-->System Prefs I believe,
I'm not on my main machine right now,
but it's the same place you set your Scratch and Capture Discs."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
I saw that in there but it always dumps to my recycling bin. hmmm?
Final Cut Pro manual, pp 672-677.
Something in your sequence is perhaps not nested,
and FCP is deleteing the renders upon you
making new changes and saving.
Follow the manual, double check what you are doing,
an try nesting the sequence. IF that doesn't work,
then try running FCP rescue, and then re-set up the
Render manager, and the Scratch Disc for FCP."Everyone has to learn, so that they can one day teach."
Urban Mac User -
Looks like I'll be busy.
fcp.file in avidemux??
By rachelH in forum Newbie / General discussionsReplies: 4Last Post: 17th Aug 2011, 16:46 -
IVTC a vob/m2v file before FCP editing
By kmxe in forum MacReplies: 18Last Post: 18th Mar 2010, 02:15 -
FCP: What is the best way to work with .m2v files in a FCP timeline?
By murraymile in forum MacReplies: 1Last Post: 23rd Jan 2009, 15:59 -
FCP not recognizing a XML file
By lcquintana in forum MacReplies: 0Last Post: 17th Oct 2008, 12:54 -
how to play QT file( DV-DVCPRO 29.97 ) in FCP without PULLDOWN
By Radoje in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 6th Jan 2008, 20:50
